02-15-2016, 02:19 PM | #1 |
Drives: 2016 Camaro 2SS Join Date: Aug 2009
BMR Suspension New Product Release-Fifth Gen Camaro/G8 Sway Bar End Links -
[FONT="Arial"]2010-2011 Chevrolet Camaro/2008-2009 Pontiac G8 Adjustable Sway Bar End Link Kit – ELK004, ELK005, ELK006, ELK007, ELK008
Reduce deflection and improve handling with adjustable sway bar end links for 2010-2011 Chevrolet Camaro and 2008-2009 Pontiac G8 from BMR Suspension. Manufactured from CNC-machined billet aluminum and heavy-duty steel hex bar stock, the BMR Adjustable End Links are designed to resist deflection, giving you the full potential of the sway bar. The links feature ball joint-style tie rods are manufactured by Proforged, which offers huge advantages over other companies’ end links that use rod ends. Ball joints allow for more articulation than a rod end, which is what you want when you hit the track. BMR’s ball joints are greasable, which you won’t find on our competitor’s end links. BMR designed the ELK kits for street performance, autocross, and road race applications. The adjustability gives you the ability to correct sway bar geometry and working angles on lowered Camaros/G8s and cars with adjustable sway bars. The adjustability also allows you to add preload and fine-tune the suspension for specific track conditions. Available in a durable black anodized finish for long-lasting good looks. Installation time is about 1 hour. Proudly made in the U.S.A.! To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email sales@bmrsuspension.com, or contact them at BMR Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055. [/FONT] |
02-15-2016, 06:23 PM | #2 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Now you come out with them LOL!!!!
Orange Krush II
02-16-2016, 08:09 AM | #3 |
Drives: Race Car Join Date: Sep 2009
I have one set left of the Old Style on Clearance for $99
05-02-2016, 08:02 PM | #4 |
Drives: 2010 Camaro SS Join Date: May 2014
I have a pfadt racing rear "balance" sway bar on my 2010 Camaro SS with stock end links. Will the BMR end link upgrade fit that bar? Or maybe another way of saying this is will the BMR end links fit the OEM bar since the pfadt bar fits OEM end links?
*Update : I got my answer through the BMR Tech email. Looks like they are designed to fit OEM bars therefore it should fit my Pfadt bar since it has OEM end links hooked up to it.
L99 - 440 RWHP
Livernois 2c Cam & VVT/DOD Delete Roto-Fab Intake Stainless Works 1 7/8" Long Tube Headers Corsa Exhaust black LED sequential tail lights Last edited by Agent 409; 05-03-2016 at 02:00 PM. |
Thread Tools | |
