Old 07-31-2015, 03:41 PM   #1
Aliveguy5
Drives: 2017 Red Hot ZL1
Water Wetter
Has anyone tried Water Wetter in their Z? and did it work? Did it cause that weird oil gunk to form like some people in other cars have had? Just curious to the results. Also if I get some I'd be adding to a 50/50 mix. Thanks in advance.
Aliveguy5 is offline   Reply With Quote
Old 07-31-2015, 07:12 PM   #2
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
water wetter says on the bottle what to expect. 8° difference with a 50/50 mix of antifreeze. 18° difference with water + water wetter. It may have helped me 5 ish degrees at the road course with a 50/50 ish mix.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 07-31-2015, 10:17 PM   #3
jayno20
Go fast, please.
jayno20's Avatar
Drives: 2019 Corvette ZR1
Would it do the same in the supercharger intercooler?
jayno20 is offline   Reply With Quote
Old 07-31-2015, 10:30 PM   #4
Expunge
Expunge's Avatar
Drives: 2013 ZL1 M6, '99 Tahoe 2Dr Sport
I use a D3 reservoir and have water wetter in that for my intercooler. Very pleased with the results.
Expunge is offline   Reply With Quote
Old 07-31-2015, 11:29 PM   #5
jayno20
Go fast, please.
jayno20's Avatar
half coolant or all water?
Old 08-04-2015, 08:00 PM   #6
Cooks ZL1
Drives: 13 Camaro ZL1
Use 100% distilled water with water wetter
Cooks ZL1 is offline   Reply With Quote
Old 08-04-2015, 10:26 PM   #7
jayno20
Go fast, please.
jayno20's Avatar
Any problems with freezing during the winter? I am garage kept, but sometimes it gets a little cold.
Old 08-05-2015, 01:43 AM   #8
wucgoode
Drives: camaro
wucgoode is offline   Reply With Quote
Old 08-05-2015, 07:51 AM   #9
cdjnight
cdjnight's Avatar
Drives: 2013 ZL1 A6
It will freeze if you use straight water with it. Basically it works better with the more water content vs. antifreeze. So if you can get away with a 80/20, 70/30, 60/40 etc...mix then it will do better for you. Just look up the coldest day for your area of living and mix your water/antifreeze accordingly to make sure your system wont freeze. Then add the water wetter...I will add that anti-freeze also helps to keep engine parts from corroding and electrolysis from happening. At minimum you should flush it all out and do again each year to keep that from happening.
cdjnight is offline   Reply With Quote
Old 08-05-2015, 11:06 AM   #10
AITI
Drives: 2015 LFX Auto
Good info. The more antifreeze, the less effective at cooling and heat transfer. I use water wetter type additives in all vehicles and SC coolant. If you live where it does not get below zero, a 70/30 water antifreeze mix with water wetter is ideal as you still have the protection against corrosion and lubricating properties for the water pump, etc. but far superior cooling ability. The absolute best as the other posters show is 100% water and water wetter.
AITI is offline   Reply With Quote
Old 08-05-2015, 03:33 PM   #11
Chrispy
11.91 ET Bone stock
Drives: 2015 Camaro ZL1
Great info!
Has anyone done before after logging to show the difference in IAT2 temps and recovery?
Chrispy is offline   Reply With Quote
