08-03-2015, 11:48 AM | #1 |
Drives: 2011 SS/ZL1 Join Date: May 2015
Project 800RWHP ZL1
Got started on the new build Sunday.
The goal is to put ATLEAST 800 to the tire... 2013 ZL1 6L90E Squash E85 fuel system FIC 127# Injectors FTI Triple Disc 3800 Stall TSP 2" Headers Afco Heat Exchanger Custom EPS Blower Cam BTR Valve Train LS9 Head Gaskets ARP Head Studs ADM Idler Setup ATI Underdrive Damper ADM Isolator ADM Blower Pulley E85 flex fuel sensor Plan to polish the blower snout and obviously the supporting gaskets with the above. Last edited by SOBBuilt; 08-03-2015 at 12:26 PM. |
08-03-2015, 11:49 AM | #2 |
11.91 ET Bone stock
Drives: 2015 Camaro ZL1 Join Date: Nov 2014
Go big or go home!
Looking forward to the results of your build. What blower are you going with? (Stocker, Heartbeat?) Your dog flaked out on the floor cracks me up |
08-03-2015, 12:11 PM | #3 |
KaBoom1701
Nice
Mods:
08-03-2015, 12:27 PM | #4 | |
Should be tuning by this weekend. Yes not only the dog but see all the empty chairs... my supervising fan club hahah |
08-03-2015, 12:35 PM | #5 |
Drives: 2014 ZL1- Summit White M6 Join Date: Aug 2014
Awesome!!
How much boost do you plan to be running? 15+?
750whp @ 13psi Garage Built on Jack Stands.. 850++ 100 shot of sauce
08-03-2015, 01:13 PM | #6 |
Drives: 2013 zl1 Join Date: Sep 2013
Am I missing something in parts? You wont see 800rwhp with that list, you will be 700rwhp. You need good heads and blower work to come close to 800rwhp
08-03-2015, 01:50 PM | #7 |
15-18lbs of boost.
Multiple ZL1s that my parts supplier deals with have this similar stage 3 setup and make 800+. Guess we will see. |
08-03-2015, 02:19 PM | #8 |
Im running btr stage 3 cam 15lbs of boost e85 and full boltons and mine and similar setups around here only manage 700rwhp. If you get 800 ill be jealous.
08-03-2015, 02:25 PM | #9 |
Drives: ZL1 Join Date: Oct 2012
You might very well be there or close being it's a E85 car. Good luck with your build.
08-03-2015, 02:38 PM | #10 |
Guess we will throw a kit on it if it doesnt!!
08-03-2015, 02:46 PM | #11 |
Drives: 2013 ZL1 A6 Join Date: Nov 2013
08-03-2015, 04:05 PM | #12 |
Pretty optimistic to hit hit 800 whp through an auto without porting heads or blower.
08-03-2015, 04:28 PM | #13 |
Drives: 2013 ZL1 Join Date: Jan 2015
I would say somewhere around 750 on e85 may be the limit from what I have seen from similar builds with an auto. I made a little over 800 with a stage 2 turbo cam and a e85 blend so it's possible.
2013 A6 ZL1
08-03-2015, 06:15 PM | #14 |
Drives: 2014 M6 ZL1 Join Date: Jan 2012
Nice build!! I would also look at porting your heads, blower, and snout. While your at it, throw one of those big boy throttle bodies and cold air intakes on there. A good tuner should be able to get you close to your number.
I'd like to know how far we can take the stock bottom end on our LSA. You may be the test bed. Keep us posted how this works out.
15' Ashen Gray Metallic Z/28
14' Crystal Red Tintcoat ZL1 6M, 9.62 at 150.75 MPH 12' Opulent Blue Metallic CTS-V Sedan, 10.690 at 129.60 MPH - SOLD 06' LeMans Blue Metallic Z06, 11.726 at 127.80 MPH Motor - SOLD. 96' Impala SS LTx, 11.397 at 118.10 MPH Motor, 1st stage 10.526 at 127.46 MPH |
