01-28-2016, 09:48 PM | #1 |
Drives: 2015 Camaro LFX A6 Join Date: Nov 2015
Tune / Throttle controller opinion
Just wondering peoples opinion on whether or not a throttle controller is necessary or worthwile if getting a proper tune. From what Im told, the tune will greatly improve throttle response which seems like it would eliminate the need for a controller. I get that the controller will technically give you more "control" but with the right tune that may not be a necessity.
I plan on getting the MRT v2 installed in addition to what I already have now before getting the tune.
Cold Air Inductions CAI : Apex Air Scoop / WW Relocate Kit : JacFab Intake Manifold Spacer : Overkill 80mm Throttle Body : Overkill Tuned : MagnaFlow Cat-Back Exhaust : Elite Engineering Catch Can : ZL1 Strut Tower Brace : Custom Tunnel Brace : JPSS Caster Locks : JPSS 32mm Rear Sway Bar : JPSS Billet Radius Arm Bushings : Pegasus Solid Sub Frame Bushings : 1LE Brembo Conversion : B&M 70273 Trans Cooler
