02-11-2013, 09:38 AM | #1 |
Drives: 2011 Camaro 2SS L-99 Join Date: May 2012
should I get some new stock OEM Gaskets for a new set of Long tube headers
I'm waiting to get my new Headers from Maryland Speed & was wondering if I should go to a Chevrolet dealer & buy some OEM Gaskets for the swap??? I pretty sure that the Kooks Headers I'm getting comes with Gaskets But I heard they are not as good as the OEM ones. So does anybody think I should try to go to the chevy dealer & get a set of OEM ones?????
02-11-2013, 09:42 AM | #2 |
9691 & 97586
Drives: 2010 SS, 1999 SS, 1993 Z28 Join Date: Mar 2009
if you haven't removed the manifolds before now... the existing ones you have will work for the headers. The factory ones are good for one header swap. If you're gonna buy new... certainly do OEM. I bought mine for 13.00 each
02-11-2013, 09:58 AM | #3 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
The factory headers are good for many swaps. On my 4th gen I've had them on since I had an Ls1, and many on's and off's. now there's an Ls3 in it and still same gaskets lol.
02-11-2013, 11:18 AM | #4 | ||
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Some people just feel the need to start fresh and that's certainly fine, as long as you use a new OEM gasket. That being said, like my "search" protege litle88 pointed out, your stock one is perfectly fine until it gets damaged.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
02-11-2013, 11:19 AM | #5 |
Drives: 2010 camaro ss Join Date: Nov 2012
I've reused mine at least 10 times. Still no leaks, they are excellent gaskets
02-11-2013, 11:22 AM | #6 |
Drives: '11 Cammed LS3, '14 Scion FRS Join Date: Dec 2011
Just use the stock ones.
SOLD with a Z06 in the not too distant future: Cammed, boltons, axles, lowered, and more. | 476 WHP |
02-11-2013, 11:36 AM | #7 |
We recommend using OEM GM gaskets. You can get away with reusing them, but we recommend new.
Best regards, Tyler 888-308-6007 |
02-11-2013, 12:18 PM | #8 |
I reused mine and they had 30k miles on them.
02-11-2013, 02:03 PM | #9 |
Might as well. They're cheap. All the installers I talked to before I did mine recommended replacing them with new OEM ones.
02-11-2013, 02:50 PM | #10 | |
Drives: '15 Z06, '01 NBM SS, '97 SS Join Date: May 2009
But do consider that they will be perfect for reuse at least 3-5 times. After that, I'd toss em. $13 is like 2 extra value meals at the BK Lounge....... Ivan @ Southwest Speed |
02-11-2013, 02:53 PM | #11 |
Drives: 2011 camaro ss vortech supercharged Join Date: Aug 2011
i used my stock ones with no problems.
02-11-2013, 08:55 PM | #12 |
Drives: 2011 cyber gray SS Join Date: Oct 2012
Use stock ones
02-11-2013, 09:01 PM | #13 |
Drives: 2010 2SS Join Date: Jan 2013
If it comes with gaskets, might aswell use them. If not, reuse your oem gaskets. Your car will not explode with oem gaskets. You'll be fine
02-11-2013, 09:33 PM | #14 | |
[COTW 4/13/15]
Drives: Supercharged LLT Join Date: Jul 2010
Sorry to thread jack but i re-used my stock gaskets for my LT's and no leaks
