10-19-2013, 10:00 AM | #1 |
Drives: 2011 2SS Join Date: Jun 2013
squash/aermotive/lpe pumps
I am going to be in the market for a fuel pump soon and am trying to figure out what would best suite my needs I am running a Maggie and will be running about 9.5 lbs of boost prob making 600rwhp and maybe more in the future I think I want the ability to run e85 if I decide to and so far it looks like only squash can do this can anyone confirm this. Also if e85 was not something I was going to do what pump would you run and why...
2011 2SS,fti th400, ECS 1500, Flex Fuel, Boost built 376, squash fuel system
10-19-2013, 10:52 AM | #2 |
Drives: 2010 2SS/RS LS3 A6 Join Date: Mar 2011
I've heard the LPE twin pumps are pretty amazing but also know several people, including myself who run Aeromotive and are good well into the 600-700 range. I've heard all of them are good with e85. I've run e85 with my stock pump with no problems at all.
10-19-2013, 10:55 AM | #3 |
Drives: V10 BMW M5, Supercharged 2SS/RS Join Date: Jun 2010
Squash, period.
MAST 416 STROKER: STAGE 3 TVS 2300 CUSTOM CAM TPIS 102 TB IW 8 RIB PULLEY W/ OD COG REARS NX EXPRESS/NANO KIT KDI HEAT EXCHANGER/ROTOFAB RESERVOIR CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER DSS DRIVESHAFT/1400 HP AXLES EATON TRUETRAC -LPE 3.27 GEARS DYNATECH HEADERS/MAGNAFLOW EXHAUST SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL BMR/EIBACH SUSPENSION KILL MODE, ON. |
10-19-2013, 11:15 AM | #4 |
with the squash what is the deal with the hobs switch/wire harness is this something I would def want to include it I went squash
10-19-2013, 11:15 AM | #5 |
Fore makes some great options too.
Nick
Corvette Z06 -1200ish rwhp |
10-19-2013, 11:21 AM | #6 |
Hobbs controls the secondary pump. Don't think twice about it. Best solution thus far for the 5th gen.
10-19-2013, 11:26 AM | #7 |
so the hobbs is a must why would anyone not get the hobbs deal?
10-19-2013, 11:36 AM | #8 |
You don't need a hobbs on a track only setup.
10-19-2013, 11:37 AM | #9 |
Drives: 2010 Camaro Join Date: Feb 2010
Pm me. I'm taking out my LPE for a squash kit very very soon.
10-20-2013, 05:25 AM | #10 |
Drives: Blown G8 GT Join Date: Apr 2010
Squash is the way to go. His kits are top notch and come complete with everything you need.
Hobbs switch helps with pump longevity. You don't need both pumps running all the time, so when the Hobbs switch sees boost, it kicks the second pump on. I have the squash fuel system in my g8, with twin dw300 pumps, e85 approved and capable of a lot of power. His pumps are a work of art This is his complete return style kit with rails and ptfe lines |
10-20-2013, 07:25 AM | #11 |
Only drives on Sundays
Drives: '16 2SS A8 NPP MRC NGray Join Date: Feb 2011
My Aeromotive is noisy and has a cavitation problem, so I'm thinking of switching out.
Got any links on the Squash? Padre |
10-20-2013, 07:27 AM | #12 | |
10-20-2013, 09:31 AM | #13 |
WICKDSS
Drives: 2011 1SS/RS IOM LS3 Join Date: May 2010
I run the squash setup, e85 capable and I'm and 630+ to the tire with plenty of fuel. The Hobbs is a simple hookup. If you go squash, Get the pre made wiring harness, nicely done and quick and easy to lay out and hook up. Pump noise is barely noticeable also. I will have to say, I do get vapor weep from the base kit hose. I would go ptfe hose. Its not cheap but it's the heart of your system, don't cheap out on a fuel system if your serious about power.
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei 11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds. |
10-20-2013, 10:02 AM | #14 | |
The Squash returnless system is on the home stretch. If you can hold out and wait it'll be the best thing since sliced bread. It'll be in my car very soon. I will let everyone know how it is. |
Thread Tools | |
