12-30-2014, 11:05 AM | #1 |
Drives: 16 Camaro SS w/ Roto-fab CAI Join Date: May 2009
Roto-fab 2012-14 Camaro radiator covers are now available!
Roto-fab 2012-14 Camaro radiator covers are now available! Adding a Roto-fab radiator cover will give your engine compartment a cleaner look by concealing the radiator, cooling fans and wiring while contouring the Roto-fab intake elbow and other components. Our radiator covers are designed to be used with Roto-fab intakes systems but will work with some other systems as well. The covers are available in texture black, automotive paint in any Camaro color, carbon fiber hydrographic finish or bare for those who wish to finish themselves. The texture black powdercoat finish is a close match to the appearance of the OEM fuse relay cover and the Roto-fab black intake elbows. We have three variations of this cover:
2012-13 Camaro SS radiator cover 2014 Camaro SS radiator cover 2012-14 Camaro V6 radiator cover Our radiator covers install easily using factory mounting points for the brackets. Once the two brackets are installed, the cover itself mounts with four push fasteners. Note: The 2014 SS requires a different cover with a recessed area for the extractor ducts on the bottom side of the hood. If you have installed a 2014 SS hood on your 2012-13 SS, you will need the 2014 radiator cover. We are posting pictures of the mounting brackets as well to give you a better understanding of how they attach. Check out our gallery on our website! Thanks for looking! Some of these pitures are of the 2010-11 V8 to give you an idea of color options. |
