03-23-2012, 08:44 PM | #687 |
Drives: 5th Gen Join Date: Feb 2010
Here's mine...Katech valve covers, coil relocation, tensioner, heater hose relocation, fuel line roto fab plenum cover, painted hall tech cai...very cool thread btw
03-23-2012, 10:06 PM | #688 | |
Furious Shine
Drives: None Join Date: Mar 2011
WOW I spend a day in the garage and come back to see all hell has broken loose here! Big flood of traffic from the homepage mention - hope they did not all rush out to relocate their battery cables (sorry Nathan)! |
03-23-2012, 10:39 PM | #689 | |
Drives: G5.R Join Date: Sep 2010
Indy, pm me your address. I have some stuffing I'm going to send I wont be using. |
03-23-2012, 10:45 PM | #690 |
Furious Shine
Well I am already Inferno Orange lol! Not sure what stuffing means but thanks I guess - I will pm you my address
03-23-2012, 10:49 PM | #691 | |
03-23-2012, 10:56 PM | #692 |
Furious Shine
03-23-2012, 11:52 PM | #693 | ||
Thanks man!
Very Nice! Quote:
I just got home and read my post. I hate posting from my I-phone. Never know what "auto correct" will replace your words with. |
03-24-2012, 07:46 AM | #694 |
Top Down Fun
Drives: 11 2SS/RS IOM Vert Join Date: Jun 2009
congrats on the homepage, been subscribed for quite a while, will be quite a while before I try to tackle this, but thanks for building such a great reference Nate!
2011 Chevrolet Camaro Convertible 2SS RS M6 IOM Vert! IO Interior, Factory Hurst, Painted GFX, Black Rally Stripes, Front/Rear/Bowtie Blackouts, QTP Cutouts, Extra Cupholders!
LED Tails, LED DRL's (always on!), Ghosted "Concept" LED Side Markers, LED Tag Lights, Tinted LED Reverse Lights, Chrome Front Turn Signal Bulbs! My Build Thread Daily Driver: 2016 Ford Fusion Titanium with 2 car seats in the back! |
03-24-2012, 07:54 AM | #695 | |
Drives: cts-v Join Date: Dec 2011
That is the tank I just installed in the car 2 days ago, lol. I don't foresee there being a size issue with it. That tank should give you plenty of room for expansion. It basically just depends on your coolant capacity and rad. cap. The more coolant capacity you have the more expansion you will get (more molecules to grow). The lower the pressure rad. cap you use, the more expanding coolant it will pass to your tank. As long as your rad. cap is good you should be ok . We have run those tanks on many high HP vehicles. As for mounting, it comes with a two bolt flanged ring that you pass the tank through. I mounted it to the frame pretty much where the factory tank was, just wanted that ugly plastic thing out of there. I'll post up pics when I'm done with the car in a couple weeks, right now its just an empty shell. -Kyle
03-24-2012, 08:05 AM | #696 |
Thanks...that was the best $2800 I ever spent!!!
Thanks !!
2020 Range Rover Sport HSE P525 Supercharged 5.0 - Firenze Red - 9012 wheels
SOLD 2019 Camaro SS -Wrapped in Matte Magnectic Black - Anderson Carbon Hood and Rear Spoiler Ikon front spoiler OEM ZL1 Side Rockers - ZL1 Addons Diffuser - BMR 1.0 Lowering Springs - MRR 228 Wheels 20x10 and 20x11 RIP 2016 Camaro SS https://www.camaro6.com/forums/showthread.php?t=565453 SOLD 2010 Camaro SS Featured in GM High Tech Performance and Camaro Now Magazines - http://www.superchevy.com/features/g...of-perfection/ |
03-24-2012, 09:04 AM | #697 |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
The great thing about this thread is you can pick and choose which parts of it you want to use. It is not one single project that must all be done.
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein |
03-24-2012, 09:22 AM | #698 | |||
Nate Quote:
Paul, that's absolutely right. Most any one thing could be done in a day. It's the old adage..... how do you eat an elephant? Last edited by Moreno1; 03-24-2012 at 12:49 PM. |
03-24-2012, 11:02 PM | #699 |
Furious Shine
Hey all! Coil brackets are mounted now - really helps to have a 2nd person hold them to help line up right (thanks Mr. hrpiii ). I am going to really address the install of these because you can never have to much info on a project like this.
Even with a right angle drill I had to remove the fans and both radiator hoses. The passenger side was the easiest, the drivers side has lots of mostly non-flexible lines in the way.. I used 1/4"x1" self-tapping screws and an extra washer to mount them. I used a new titanium 13/64" drill bit which went through the frame rails pretty easily. Just drive the self-tapping screw in with a socket and hammer to get it started. Ideally you would mount the bracket with coils already installed but with my 1" screws I could not get the threads started enough. So I mounted an empty bracket and installed the coils afterwords (it is tight but doable)! The best recommendation I can give is to install the coils in the bracket and then move it along the frame rail until you find a spot that is the most "free & clear". Pay particular note of clearance for the wire harnesses on the bottom, and plug wires on the top!! Also make a note (tape on the frame rails works) before removing the fans, so you know how far they stick out from the radiator. You don't want to mount the bracket to close to them or they may hit. Then disassemble the coil bracket and use that to mark and line up your holes. The drivers side is a bit more difficult navigating around the hard lines. I only removed upper & lower radiator hoses - so I navigated around these best I could. I ended up with one hose passing between the coils no matter what I did, So I test fitted with the stock plug wires and found the "sweet spot" where I could still get the plug wires on. One key thing I thought of while assembling these in the brackets - insert the long carriage bolts starting from the firewall side and and put the nuts on the radiator side. This way if you ever have to remove them you should not have to remove the fan assembly again (you need several inches for the bolts to slide out and clear) the coils. I test fitted my 52" coil harness extensions from Casper's (running out the rear of the engine), and they lined up perfectly! Note - these pics are with the fans still removed, so there will not be this much space between the brackets and radiator when you are done. |
03-25-2012, 12:03 AM | #700 |
Drives: cars Join Date: May 2011
Everyone harass the piss out of these guys to make a chrome water pump for us.
http://www.tuffstuffperformance.com/...od/prd9123.htm |
Similar Threads | ||||
Roto-Fab | Engine Covers - S/C | Fuse Relay Cover | Radiator Cover | Billet Oil Cap+ | AutoAgenda | Exterior Parts & Accessories | 14 | 02-06-2013 08:43 PM |
New Texas Speed & Performance Engine Machining Center! | Trevor @ Texas Speed | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 18 | 01-16-2013 03:46 PM |
Hawk Performance Brake Pads part HB247Z.575 $85.00 | Rogan | USA - Florida | 2 | 10-07-2011 12:10 PM |
Acronyms? | KEEP RT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 20 | 03-11-2011 08:57 PM |
Great Read and Info on Oil Weight | Banshee | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 1 | 11-23-2009 09:03 PM |
