09-17-2010, 09:02 PM | #1 |
Drives: 2010 2SS L99 rally yellow Join Date: Aug 2010
CAI pipe get too hot?
I heard that if the cai pipe to intake gets too hot, loss of air happens. Does the pipe need to be wrapped or is this not true?
01-18-2012, 07:36 AM | #2 |
Drives: 2012 2SS L99 Join Date: Nov 2011
01-18-2012, 07:41 AM | #3 |
Drives: 2010 Camaro SS LS3 Join Date: Sep 2010
It does get very hot, but wrapping it would only help hold the heat in. CAI ceramic coats the pipe so ideally it's only hot outside not in. That said, if you want to know if that is true, go for a nice long drive in the summer, as soon as you get home, pull the filter and stick your hand/arm inside of the tube.
She is only memory now. |
01-18-2012, 07:48 AM | #4 |
Drives: 2006 twin turbo Corvette Z06 Join Date: Nov 2011
You won't lose airflow because the pipe is hot. People usually just get over concerned with "heat soaking" the IAT sensor built into the MAF. What they fail to realize is that as soon as you go WOT, the substantially higher airflow makes the IAT react to what's actually coming in.
01-18-2012, 08:52 AM | #5 | |
Drives: 2SS/RS Join Date: Sep 2008
The tube being hot is a good thing. This means it is not transferring that heat to the air inside the tube. If you go for a drive and the tube is only warm is when I would be worried. |
Similar Threads | ||||
V8 Camaro Performance Upgrades List | Milk 1027 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 93 | 08-30-2021 05:56 PM |
g5cr cai system anybody install or looking at one "pics" | camarossrs2150 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 41 | 07-14-2011 08:26 PM |
1 3/4's vs 1 7/8's Headers | brAnd7onX | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 28 | 01-11-2010 05:43 PM |
AirAid Cold Air Intake anyone? | FLYNNZL1 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 12 | 01-01-2010 09:05 PM |
Hot Rod Power Tour Featuring the Concept Camaro Convertible | TAG UR IT | 5th Gen Camaro SS LS LT General Discussions | 14 | 09-18-2007 05:08 PM |
