09-09-2014, 07:17 PM | #1 |
Steve from Canada.
Drives: 2010 SW SS/RS with Inferno package. Join Date: Mar 2009
L/F opinions on drilled rotors!
Best rotors to buy for everyday driving in my 2010 SS?
Best place to buy them? Thanks.
09-09-2014, 10:58 PM | #2 |
Drives: '12 2LT Convertible Join Date: Mar 2012
OEM or DBA
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
09-09-2014, 11:16 PM | #3 |
Caffeine Injected
Drives: 13 Ram - 05 Widebody 1050rwhp Vette Join Date: Sep 2010
The best for the factory brakes would be Racing Brake's rotors, might be a little overkill for your looking for and they're slotted not drilled.
The best place to buy them would be Apex. Aside from that, I would probably just stick to OEM rotors, but I have also put R1Concepts on 2 different vehicles and had no problems, Apex also sells the R1Concepts. Also you usually get what your pay for when it comes to Pads, so keep that in mind as well. Last edited by nitto85; 09-09-2014 at 11:35 PM. |
09-10-2014, 05:02 AM | #4 |
Too much is never enough!
I like my R1 premier cross drilled and slotted rotors. I bought them from Apex. I get them pretty hot on a regular basis and no warping.
