04-11-2021, 04:57 PM | #1 |
Drives: 2010 SS/RS M6 BIG cam Join Date: Mar 2016
Whats really needed ? Gear change
I want to start ordering parts for doing gear change. Yukon 4.11 is my gear set of choice. I want to spend little as possible on the install parts. My car only has 15k miles on it so only want the bare minimum of what is actually needed.
If some one could give a quick parts list for a budget gear change it would be greatly appreciated
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
04-11-2021, 05:04 PM | #2 |
Here we go!! Another one.
04-11-2021, 06:47 PM | #3 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
Not trying to be an a** but I’m not sure that gears is where I would cheap out at. Just my opinion and you know what opinions are.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
04-11-2021, 06:50 PM | #4 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Best/easiest/least expensive in the long run is to call a good speed shop or transmission shop and have it done right the first time.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
04-11-2021, 06:54 PM | #5 |
Drives: 2011 Camaro SS Join Date: Jul 2019
No such thing as cheap and reliable. Hope youre not getting an exhaust ...
EPS CUSTOM GRIND CAM....K@N CAI....VMAX PTB.....FRANKENSTEIN STAGE 2 HEADS ...1 7/8 STAINLESS POWER CATTED LONGTUBE HEADERS...CORSA XTREME 3 INCH CATBACK.....CIRCLE D 3800 Pro Series stall...391 gears.....Ported/modded GPI intake .Forgestar drag pack with Mickey Thompson ET street drag radials AGP PERFORMANCE DYNO TUNED. 463 WHP 428 FTLBS TORQUE.
04-11-2021, 07:40 PM | #6 |
^^ exactly this... Money ahead..
04-11-2021, 08:23 PM | #7 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
The base AAM kit comes with just gears, bolts, and a crush sleeve. However there is a good chance you will jack up the pinion bearing when you try to take it off. You do need a pinion seal, but only need output seals if you mess one up. There are numerous threads in the drivetrain section. A bunch of guys have done them, but a bunch of guys have messed them up. If you you don't know what parts you need, you might be in over your head. Search is your friend.
If you are going with Yukon gears just ask Randy's what you need. Their prices are good as any and they know what they are talking about.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
04-11-2021, 09:36 PM | #8 | |
For starters thank you. Secondary is Randy's a person or company ? Also is the pinion bearing I.D the same for aftermarket as oem , "new stock ss pinion bearing can be used?"
04-12-2021, 05:08 AM | #9 |
Randy's Ring and Pinion
There is also West Coast Gear They both specialize in diff parts. OEM bearings should fit aftermarket gears, but you can confirm that with the sellers.
04-12-2021, 09:52 AM | #10 |
For pinion seal, I would definitely go with an OEM pinion seal instead of a cheaper aftermarket one (not much of a price difference anyway). I know a few people that went with the aftermarket seal and it leaked right away.
2014 2SS/RS - Red Rock Metallic - Kooks Headers, Corsa Extreme, Factory Reproductions Z28 Rims, Pedders Coilovers, JDP Clutch Reservoir, Summit Racing Line Lock, GM Strut Brace, GM low profile splash guards, Roto-fab CAI, Oracle Ghosted Sidemarker Lights & Concept Mirrors, ZL1 Side Skirts, MGW Flat Stick Shifter, BMR Subframe Connectors, Eaton Truetrac, Yukon 4.11s, GForce Renegade Axles, Speedmaster79 Diff Cover, Offset Diff Bushings, Every Suspension Bushing Front & Rear Replaced with BMR Poly Bushings - 421HP 412TQ
04-12-2021, 11:33 PM | #11 | |
Drives: Silver 2014 Camaro 2SS Join Date: Dec 2018
The gears are Motive which I didn’t really want due to subpar reviews. But it’s all they had. No issues so far. Faint whine between 42-48mph.
2014 Silver 2SS L99 with Roto-Fab CAI, Kooks LT Headers, Kooks Cat-less 3” exhaust, TS Stage 3.2 VVT CAM, Circle D 3200 Stall, E85 Kit, FIC 850cc injectors and Elite Engineering Catch Can. Dynoed at 478rwhp.
