07-10-2015, 09:10 AM | #1 |
All About That Speed
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2013
Camaro Belly Pan
Came across this belly pan this morning when I was looking for some parts and figured I would post it here for those who are interested in it.
Has anybody installed this one before? Click Here
2010 SS M6 | 416 CI | H/C/I | GPI TUNED | SNSSTR |
07-10-2015, 10:04 AM | #2 |
Drives: 2013 Camaro 1LE Join Date: Jul 2012
I put the 2014/15 Z/28 belly pan on my 2013 1LE. I think the Z/28 pan goes a little further back. But it did require trimming about 1" off the underside of the front bumper cover to allow the Z/28 Belly Pan to fit properly. I'm not sure if your 2010 will have the factory holes in the bottom of the subframe though for the threaded nut inserts to clip into. There is a thread in the Z/28 sub-forum and also one in the 1LE sub-forum I believe that both talk about the Z/28 belly pan install.
EDIT: Here's the one in the Z/28 sub-forum: http://www.camaro5.com/forums/showth...64#post8054364 Here's the one in the 1LE sub-forum: http://www.camaro5.com/forums/showth...20#post8110320
Last edited by Nick S; 07-10-2015 at 10:07 AM. Reason: Added links to other threads |
07-10-2015, 10:13 AM | #3 |
Drives: pleather and Chiclets Join Date: Mar 2012
Member name bananom made his own. A lot use the z28 or zl1.
