02-12-2015, 07:20 PM | #1 |
First time at the drag strip
I'm going to a drag strip for the first time . I've always been a street racer but age has a way of changing things .
I'm 640 RWH on a mustang dyno and m6. I just bought a set of bogarts 17" with 325 m/h drag radials and I have another set of 20" pilot ss 315 coming in soon . I know the drag radials will stick better but what are my chances of blowing a axle or rear end if I hook . I'm not sure if I should put the 325 ,s on until I beef up the axles and rear end . Any advice would be greatly appreciated .
02-12-2015, 07:22 PM | #2 |
Drives: 2014 Join Date: Sep 2013
Wait till they plow the snow off......
02-12-2015, 07:28 PM | #3 |
Lol , this isn't happening till spring . If the snow ever ends .
02-13-2015, 09:37 AM | #4 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
I'm never one to suggest spending money on fancy parts, but I think you need aftermarket axles.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
02-13-2015, 09:54 AM | #5 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
ZL1 rear and axles.
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
02-13-2015, 03:13 PM | #6 |
02-13-2015, 06:02 PM | #7 |
I'm going to install a dss drive shaft and dss 1000 hp axles before I hit the strip . I was going to try and install a new clutch first but maybe the axles and drive shaft should be first. Thanks for the input.
02-15-2015, 04:59 AM | #8 |
Drives: My wife crazy with my C5 usage. Join Date: Apr 2009
Drive shaft isn't needed. I'd get a Trutrac, axles and gears. Since you're going to open it up, knock it all out at once. The rear housing can take more than what you're giving it.
I'm sitting right about where you are and a good pass on 20" P-Zeros gets me booted for no cage. Sent from my iPhone using Tapatalk
