Old 05-26-2013, 11:36 AM   #1
Vader2011v6
Vader2011v6's Avatar
Drives: 2014 custom blue ZL1
All set and ready to drag my Ipf v6 Camaro
So just installed my new NGK spark plugs with correct heat range and gap.new SLP short shifter with knob. Also my new Aftermarket drive shaft from the drive shaft shop.hopefully nothing breaks again. Goin to sac raceway this Wednesday for practice for Super Chevy this coming weekend.
Vader2011v6 is offline   Reply With Quote
Old 05-26-2013, 02:36 PM   #2
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
The NGKs made a difference in the overall running.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 05-26-2013, 03:24 PM   #3
Vader2011v6
Oh yeah. My car feels so much smoother. I used to have a little hesitation here and there. Now it's completely gone so glad I decided to do it before the race.
Old 05-26-2013, 03:51 PM   #4
IBM camaro
Texas HT5
Drives: IBM
Good luck man
IBM camaro is offline   Reply With Quote
Old 05-26-2013, 04:04 PM   #5
Mvp_Me
I Use Three Pedals
Mvp_Me's Avatar
Drives: 2011 VR M6
What NGK's are you running? also what was the gap you put on them? i might switch from the stock ones.
Mvp_Me is offline   Reply With Quote
Old 05-26-2013, 04:49 PM   #6
Nutbutt
Nutbutt's Avatar
Running the NGK LTR7IX-11 at a gap of .034
Old 05-26-2013, 05:34 PM   #7
Mvp_Me
I Use Three Pedals
Mvp_Me's Avatar
Drives: 2011 VR M6
ok, thanks. all i have is a intake but if these make the car run better ill use these from now on. im going to try them tomorrow if i have time.
Old 05-26-2013, 05:47 PM   #8
blackTT600
Drives: 2011 2LT M6 SC
Did you break something last time?
blackTT600 is offline   Reply With Quote
Old 05-26-2013, 06:39 PM   #9
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Just a heads-up Mvp, these guys are all running IPF superchargers and that particular NGK would probably be not be an improvement in a car without some forced induction system.
Old 05-26-2013, 07:53 PM   #10
Mvp_Me
I Use Three Pedals
Mvp_Me's Avatar
Drives: 2011 VR M6
Thanks for the heads up, i so didnt catch that
Old 05-26-2013, 08:09 PM   #11
sycraft
COTW 5/06/2013
sycraft's Avatar
Will that work in the LFX too
Old 05-26-2013, 10:43 PM   #12
KMPrenger
KMPrenger's Avatar
Good luck man. Looking forward to your results. Have you taken her down this track before either before or after supercharging your car? If so, what did you get?
Old 05-27-2013, 03:43 AM   #13
Vader2011v6
Running the NGK LTR7IX-11 at a gap of .032
Old 05-27-2013, 03:46 AM   #14
Vader2011v6
Thanks everyone. Took my car when it was stock with some heavy 20's and ran 14.52 @ 96.54 mph. Took the car with the supercharger and broke my drive shaft bolts while warming up my tires at a low rpm. I didn't get one run down the track.thats what made me get a new stronger driveshaft.
