04-15-2014, 01:27 PM | #1 |
Drives: 2010 2SS Join Date: Sep 2012
service stabilitrak interfering with efilive?
plugged in my autocal and it wont data log. error $2081. is this due to my service stabilitrak issue by any chance? i just had rear cradle out and suspension done. going to chevy soon to reset it or troubleshoot the issue.
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
