05-30-2016, 03:54 PM | #1 |
Need your help friends! Stuck with 10mm bolt (front engine cover)
Working on cam swap and stuck for a second day at the point of removal the front engine cover. One bolt that hold the plate from underneath (pass. side, comes from oil pan) failed to get extracted. I put tons of diff. chemical sprays (literally writing under influence) on it, did some hammer work with a wrench but nothing. Frustrating as I wanted to accomplish everything during this long weekend. The bolt size is 10mm but right now it is more like 9.5mm. Trying to use "Irvin" grip bolt extractor but the 10mm tool is too big now and 9mm will not fit. I am trying to "tear" down that bolt using pliers and rasp (file). I used to get some good results in the past (headers install) using "Liquid wrench" so my next step is to get this spray, as well as continue my work using a file and pliers.
But I would appreciate any brilliant idea on how to get that bolt extracted asap. P.S. have some photos but my affected brain fails to find a way on how to upload them. Thanks friends and Happy Memorial Day! |
05-30-2016, 05:22 PM | #2 |
05-30-2016, 05:28 PM | #3 |
KNGTFALL
Drives: 2012 2SS 45th edition Join Date: Aug 2012
If you can get one of those mini pipe wrenches like a 4 inch they usually will remove stripped headed bolts. Vice grips and channel locks destroy hex heads.
Not even sure if you can get it in there with the clearance. |
05-30-2016, 05:46 PM | #4 | |
4in will not fit
heading to Home Depot to see if I can get some smaller pipe wrench. Again, thanks for heads up! |
05-30-2016, 05:52 PM | #5 |
just realized I have small pipe wrench, it didn't work, just rounded the bolt a bit more.
Will keep looking, thanks again |
05-30-2016, 07:21 PM | #6 |
Drives: '10 Black/IOM Camaro SS/RS Join Date: Mar 2010
Would help if you could post pics. You can try to heat it up with a torch or weld a nut to whats left of the head
2010 Camaro 2SS/RS Black/IOM //// 1998 Pontiac Trans AM 819 RWHP @ 12 PSI (Turbo)
05-30-2016, 07:41 PM | #7 |
pics
Some pics
tks Last edited by rvadim76; 05-30-2016 at 08:25 PM. Reason: pics |
05-30-2016, 08:26 PM | #8 |
Sorry for quality, it's not easy to get there, the car is on the stands only
05-30-2016, 09:03 PM | #9 |
Too many cars
Drives: 2015 Camaro 2SS 1LE Join Date: May 2016
Buy a cheap 9mm socket, hammer it on and get some MAPP gas from Home Depot.. Heat it up and turn.. It'll work.. I promise
2015 2SS/ Summit White RS 1LE NPP NAV Recaros
I got a big ass garage and I'm not afraid to use it. |
05-30-2016, 11:26 PM | #10 |
06-02-2016, 11:11 AM | #11 |
Well, gonna ask about this wrench:
http://www.amazon.com/LoggerHead-Too...ols+BG6-01R-01 is there anyone who used this tool? Was it a good experience? Still hesitant to use a torch as there is tight spot and a/c pipes and wiring. Put more liquid wrench chemical overnight and have broken 2 sockets so far no luck. Hope this wrench can help.. |
06-02-2016, 01:27 PM | #12 |
bump..
06-02-2016, 02:13 PM | #13 |
Drives: 2009 ZR1 Join Date: May 2010
Something else you can try.... If you have a dremel, cut a slot in it and use a big screwdriver. That's a last resort as you can really diminish the head and lose the ability to grasp it at all.
If you have a welder, you can weld another bolt to it and use it to turn. |
06-02-2016, 03:54 PM | #14 |
have you tried these?
Tags |
bolt extractor |
