11-07-2014, 01:48 PM | #1 |
Rotate tires?
I never had a car that had "staggered tires" I would normally rotate the front diverside with the rear driverside, and the same with the passenger side. This may be a stupid question, but do I swap the back tires? That goes against the little I know about tire rotation.
2013 SS owner in So. Cal. |
11-07-2014, 01:54 PM | #2 |
Drives: Evil Eva, 2010 2SS LS3 Join Date: Aug 2013
No, they don't get rotated.
If you switched to a "square" setup you could
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
11-08-2014, 10:39 AM | #3 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
For what its worth, you can rotate side to side. I have done it. Its amazing how each tire wears differently.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
11-08-2014, 11:04 AM | #4 |
'It's an experiment'
as long as they are not direction -- side to side may work. My ZL1 GoodYears I have on my 2SS are directional so I would not be able to rotate them.
-Don |
