04-22-2013, 03:17 PM | #1 |
Drives: 2010 2SSRS headers/CAI/tune/corsa, Join Date: May 2010
alignment & suspension mods wheel stick out?
TSW Nurburgring wheels 315/35/20 tires Pfadt trailing arms & tie rods sway bars. Pedders street 1 package. After install the left rear wheel sticks
out 1/4 inch more then the right wheel .? Is this from the wheel alignment . it was not that way before suspension mods. Seems to drive fine.
Stainless works headers/cats Roto fab CAI /
Corsa install and tune Livernois TSW Nuburgring 9 &10" x 20 on Invos (315 & 275 ) JL Audio XD400/4 amp Pfadt trailing arms & tie rods sway bars. pedders street 1 package. ,Hurst short throw shifter With bronze bushings . |
04-22-2013, 03:33 PM | #2 |
Drives: cars Join Date: May 2011
It would only be alignment if it were way off. The cradle is located with pins so its not off center. My guess would be the offsets of the wheels should be investigated if those are new too. Then confirm length of arms are equal on each side and alignment numbers.
04-22-2013, 03:52 PM | #3 | |
Not new wheels they been on for some time. Yes they have aggressive offsets But both wheels use to be flush with fender now on side is in a tad (1/8 inch ) other side sticks out ?( 1/4 inch.)
04-22-2013, 04:04 PM | #4 |
Sounds like the camber is off to me. Have you had it aligned yet?
Best regards, Tyler 888-308-6007 |
04-22-2013, 04:16 PM | #5 | |
And upgrades are from you guys. Seems to drive Fine . You have to look real hard to tell. Like I said .200 to .250 difference One side to the other. Should I be concern ?
Corsa install and tune Livernois TSW Nuburgring 9 &10" x 20 on Invos (315 & 275 ) JL Audio XD400/4 amp Pfadt trailing arms & tie rods sway bars. pedders street 1 package. ,Hurst short throw shifter With bronze bushings . Last edited by skar; 04-22-2013 at 06:12 PM. |
04-22-2013, 04:17 PM | #6 |
Get the printout.
04-22-2013, 04:42 PM | #7 |
It was the toe that was maxed out but in specs.
The guy who did the install did it at his house and he took It to ? For the alignment . And yes I trust his work.
04-22-2013, 05:00 PM | #8 |
Negative Camber Junkie
Drives: 2010 1SS LS3/6MN ABM 1 of 23 Join Date: May 2009
Post up some pictures taken from above looking down at the tire, both sides. Then from the side taken from the back of the car, about a foot or two off the corner of the rear bumper, so we can see the camber of the rear wheels. Then one from the rear of the car down the side, both sides again, from ground level.
With these pictures we should be able to see what kind of camber the rear tires have and whether or not they match side to side. If it is off with these views it will be noticeable. T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same. Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different. I can't wait for my next Track fix. DA HAWKS OWN DA CUP!!!!! |
04-22-2013, 06:02 PM | #9 |
? not sure.
04-22-2013, 06:06 PM | #10 |
one more
04-22-2013, 07:57 PM | #11 |
To me, it looks like your camber is off just like Tyler said.
Did you get the printout of your specs when it was aligned? If not I would be suspect and ask for it. If it can not be produced, and even if it can, I would take it back and have the alignment double checked or flat out redone. Also, did you ask for a performance street alignment, track specs or a combo of both? Taken from the Pedders 5th Gen Suspension-The Book. That is my 2 cents, no change required. T.
04-23-2013, 10:39 AM | #12 |
Drives: 2012 2SS RS Join Date: May 2012
Is it just me or is the driver side higher?
05-05-2013, 07:16 AM | #13 |
Had the car redone at Rodgers Chevrolet with pedders street specs and the left rear still
Sticks out 1/4 inch .They have state of the art hunter alignment machine. Also retimed the bushings . Must be the way the axle is mounted to the frame ?
05-08-2013, 05:49 PM | #14 |
Drives: Camaro Justice Join Date: Jun 2007
Flip the rear wheels side to side. Any change?
