Old 08-08-2013, 08:53 PM   #1
Thebabycheech2012
Thebabycheech2012's Avatar
Drives: 2010 ss2 l99
Problem turning over
So recently my car is having trouble turning over ... The code comes up as the crankshaft position sensor... So I replaced it and still doing it almost like the battery is dead n just barely turning over now ... It's not every time it does this starts in the morning fine and after letting it sit for a few hours but lets say u pull into a spot n u turned it off and u get out n go dam gota move up more u look like an idiot because its like a 1 an a 2 an a 3 An a 4444444444444444444444444 and the start then stab trac , traction control come on... I know my battery can't hold a load very well n working on replacing it but once I replace it I hope I still don't run into the same problem it's like turning so slow then it stay cracking for at least ten seconds any other ideas what it might be besides the seņor and the battery
Thebabycheech2012 is offline   Reply With Quote
Old 08-11-2013, 01:37 AM   #2
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
Bad ground or battery. As you already know you have a bad battery, that would be the first item to replace.
JimE is offline   Reply With Quote
Old 08-11-2013, 10:41 AM   #3
Thebabycheech2012
Yea I'm going to replace the battery and I think I got rid of the bad ground but like you said start with the battery
