12-29-2016, 04:42 PM | #1 |
Drives: 2014 Camaro LS Join Date: May 2015
Camaro Horn not working!?
So it's been about a week now that I haven't had a working horn. One day I tried to put alarm on my camaro but it wouldn't beep. So I checked my pressing the steering wheel and still nothing . I checked the horn fuse and replaced it. Still nothing! Any ideas? Thanks !
12-29-2016, 04:48 PM | #2 |
Drives: 2012 1LT Drop Top Join Date: Oct 2013
Since it doesn't work with your car alarm then the problem probably wont be the steering wheel switch. Put a voltmeter on the horn and check for voltage when it should be working. (Some horns may work with a switched ground. I'm not sure about ours). Horn may have just crapped out.
12-30-2016, 08:43 AM | #3 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
and just so you know.....there are actually two horns on your car, they have two different pitches.
12-30-2016, 12:59 PM | #4 |
I didn't know that and a good point. That also means that both horns probably aren't bad and it's a voltage or ground problem.
12-31-2016, 01:51 AM | #5 |
Drives: 2014 BRM 1SS/RS Join Date: Sep 2011
2014 Blue Ray Metallic 1SS/RS A Road Warrior |
12-31-2016, 07:40 PM | #6 |
Drives: 2010 SSII w RS & Sunroof Yellow Join Date: Aug 2009
Location: West Suburbs of Chicago, in a Courthouse Somewhere
01-01-2017, 10:04 AM | #7 |
NOW.....once you got the horn fixed.....and you KNOW how weak the horn is. (they aren't very loud), you may want to take a look at this!!
http://www.camaro5.com/forums/showthread.php?t=157184
07-18-2022, 12:11 PM | #8 |
Drives: Chevrolet Camaro Join Date: Jul 2022
Hello, i have the exact same issue, the horn fuse is good but nothing.
anyone knows if there is a "horn relay" and if there is one where is it located? |
07-18-2022, 12:26 PM | #9 | |
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
