01-01-2014, 08:02 PM | #1 |
JT Synergy RS/2SS
Drives: 2011 Camaro RS/2SS (L99) Synergy Join Date: May 2013
Drag radial set up (TPMS)
Hey guys,
Just wondering if I will be able to run TPMS in my drag radial set up. I purchased a separate set of 18" MT drag radials on C6 Z06 rims. I will be running my stock 20's on the street but I'd like to have sensors in my drag radial set up for when I swap them for the track. Please advise. Thanks! |
01-01-2014, 09:08 PM | #2 |
Drives: 2011camaro SS Join Date: Nov 2012
I think you can as long as you buy new sensors for the 18" wheels.
01-01-2014, 09:12 PM | #3 |
JT Synergy RS/2SS
It sounds like they will need to be reprogrammed every time on swap tires/wheels. Bummer.
Thanks |
01-01-2014, 09:25 PM | #4 |
I'm not sure about an alternate set having to be reset. When I take my street wheels off and put my slicks on, my slicks have no TPMS sensors, therefore on my rear wheels nothing shows up on the DIC.
As soon as I put my street wheels back on, the sensors pick up where they left off. I do nothing different. |
01-01-2014, 09:31 PM | #5 |
Drives: camaro turtle Join Date: Nov 2013
the pressure you should be running drag radials at (22-25 psi) for regular street driving is going to set off the tpms anyway.
This nick no longer in use. Please direct all future pms to 'Dietcoke'
01-01-2014, 09:33 PM | #6 |
COTW 12/3/12
Drives: 2012 Ashen Gray ZL1 Join Date: Aug 2011
I don't really see the point of TPMS in your drag tires. You aren't going to be using the car to read your tire pressure at the track and they are only going to on for a short time, so why the added expense. Also, most likely you will be running pressures that the TPMS isn't going to like anyway, so why do you want to see the annoying low pressure light? Skip it and save the money nene time spent reprogramming every time.
01-01-2014, 09:41 PM | #7 | |
JT Synergy RS/2SS
Thanks guys! I appreciate the advice. |
01-01-2014, 09:49 PM | #8 | |
01-01-2014, 10:02 PM | #9 | |
JT Synergy RS/2SS
I appreciate the advice guys. I'm gonna cancel the TPMS order. |
01-02-2014, 01:35 PM | #10 |
Drives: '69 SS Convertible Join Date: May 2009
I wouldn't do that unless you have to. You'll eat up your tread on the street. Drag radials have soft tread wear....good for the track but not so good on the street.
Build Journal |
01-02-2014, 02:19 PM | #11 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
Like SG0 was doing, I daily drive on DR's (NT05R) as soon as it's nice out until the fall. So I think I'll run thru a set a year. My daily commute is only 10 miles round trip. So I run TPMS in them but I bought a really nice tire gauge to use at the track.
But I'll be getting slicks for 2014 and they will not get TPMS and will not be street driven unless someone wants to run me for money.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
01-02-2014, 03:46 PM | #12 | |
JT Synergy RS/2SS
01-03-2014, 03:29 PM | #13 |
I have TPMS since I leave my DRs on most of the time. I work from home and the DRs do not wear much faster than my stock tires. For 2013s and up you need a TPMS tool. ($60). I think the older cars can re-acquire TPMS signals from the DIC settings.
I don't care about warnings the car gives me. All those pretty lights in the dash. lol. And it is nice to have some idea how much air I have in the tires. If they get hot the pounds go up.
"Democracy Dies in Darkness" |
