05-26-2011, 09:33 AM | #1 |
Drives: 2010 SIM Camaro 2SS 6speed Join Date: May 2011
I may do coil springs instead of drop springs.
I like the idea of being able to choose the ride height I like and adjust the damper rate.
What are the CONS to coil springs? (besides price) For those that have had both drops springs and coilovers, can you tell me a bit about how the coilovers compare to drops? |
05-26-2011, 09:46 AM | #2 |
Drives: 2010 Join Date: Jul 2009
Coilovers are superior to drop springs.
Coil overs allow adjustability not only in ride height, but also allow you to adjust bound/rebound to give you a soft or firm ride. |
05-26-2011, 10:50 AM | #3 |
Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
Our coilovers are my favorite product we offer for the Camaro. Having driven on both setups extensively, I can say without a doubt that if coilovers fit into your budget they are the way to go. Featuring 20 way damping adjustment our coilovers offer the flexibility to be setup for a comfortable street ride, all the way to aggressive track use. They can give you the customized lower stance your looking for, and can be corner balanced if you're searching for that last .10 of time at the track.
Drop springs do offer an increase in performance and a lowered stance, but ultimately the performance ceiling on coilovers is much higher than a set of drop springs. For street use you'll find that depending on where you have your dampers set with coilovers your car will feel much lighter and be more responsive to throttle/breaking/steering inputs, and still smooth and comfortable. As far as cons for coilovers: 1. Price, they're more expensive than drop springs. 2. Increased gas consumption when you take more "drives to the store" to spend time in your car |
05-26-2011, 11:10 AM | #4 |
"Camaro Joe"
With some coilovers depending on the company you change the spring preload depending on the hight of the car. Getting your self on a set of pedders xa coilovers Is the best way to go. They lock in the preload of the coils and adjustability comes from adjusting the shock body in to the clevis. So you never touch the spring tension again
05-26-2011, 12:31 PM | #5 | |
05-26-2011, 12:43 PM | #6 |
"Camaro Joe"
No the ride hight is fully adjustable. There is a separate ring that you adjust with the supplied wrench. The entire shock body moves not just the spring. The difference is you don't have any float issues if you over extend your suspension. With the pedders the shock travel and spring stay in sync. If you would like send me your zip and I can price you out a set
05-26-2011, 12:46 PM | #7 |
"Camaro Joe"
Jep check out the link. The man him self justice Pete will give you a better understanding of the xa coil overs Pete comes on at 4:00 of the video http://m.youtube.com/#/profile?deskt...lay=True&gl=US
05-26-2011, 12:50 PM | #8 |
Drives: 2010 SS with WAY TOO MANY MODS Join Date: Sep 2010
Having adjustable body height is not necessarily a good thing, too much adjustment, too many things to come loose. Too many variables during set up if not done ocrrectly.
Most customers, if not ALL street car customers can still benefit greatly from any coil over system. If the body design and shock travel are built into the dampers, i.e. Pfadt Racing, then unless you want the thing to ride on the ground in which case you don't really care about performance, the body height adjustment issue becomes irrelevant. For my money, and from the feedback we have gotten from every customer who has them, I would run the Pdaft Coil Over system. |
05-26-2011, 05:52 PM | #9 |
Shop Owner
Drives: 1 ton silverado Join Date: Jan 2009
First question should be. How do you plan to use your car? Look at the book on the 5th gen Camaro. All your answers will be there.
05-26-2011, 07:02 PM | #10 |
Drives: 701 RWHP Lingenfelter/Pedders Beast Join Date: Apr 2009
I agree with the coilover vs. springs....coilovers 100% better! The ability to adjust with a few clicks of a knob is awsome! As far as the ride height most people just set it down an inch to inch and a quarter then never adjust again. I have had great performance with my Pedders on both the street and track. Pfadt is also a very good one.
Here is a link to the "Book" for info:http://www.camaro5.com/forums/showthread.php?t=90270
Lingenfelter forged balanced and blueprinted LS3, Maggie TVS 2300 LPE 9.5" Rearend 3.73,LPE dual disk clutch,10/14 rib belt drive,
MTI shifter,RPM Level VI,Corsa stainless cat back, Racing Brake Rotors, LPE calipers, LPE twin fuel pumps, American Racing long tube headers, GT9 cam Port and polished heads and an ADM majic tune. 701 RWHP,Fully Pedderized w/complete bushings and Sportsryder Supercar Remote resevior coilovers. CCW 505t's Nitto Invo's and DR's Beware of the LPE Brotherhood! |
05-26-2011, 08:09 PM | #11 |
Drives: black camaro Join Date: May 2011
doesnt wheel alignment change when you change heights with coil overs?
05-26-2011, 08:39 PM | #12 |
Yes, you will have to re-align after changing the ride height.
05-27-2011, 10:13 AM | #13 |
Drives: Car Join Date: Jun 2010
05-27-2011, 10:20 AM | #14 |
knows 2 facts about ducks
interesting
Similar Threads | ||||
DIY : Install Lowering Springs on 2010 Camaro | Nine Ball | Camaro DIY & HOW-TO instructions & discussions | 42 | 03-29-2017 01:31 PM |
V6 drop springs | V6owner | Suspension / Brakes / Chassis | 6 | 03-16-2011 08:12 PM |
1" drop springs, not progressive wound | flht99b | Suspension / Brakes / Chassis | 2 | 12-22-2009 10:26 AM |
PEDDERS TAKING ORDERS FOR DROP COILS WITH OPTIONS! | Info@PeddersUSA.com | Suspension / Chassis / Brakes | 25 | 08-03-2009 10:45 PM |
Detroit Speed vs. Pedders | usmcjlp | Wheels and Tires Talk Sponsored by The Tire Rack | 35 | 07-22-2009 12:14 AM |
