12-29-2012, 04:06 PM | #1 |
CAROMARO
Drives: 2012 Ashen Gray 1LT Join Date: Aug 2012
Amp and ******** harness install problems
I installed the ******** non B.A. harness and amp today and when I powered it up I have no rear speakers. Also when I even try and give it any volume I lose the right front. Help anyone. If anybody else has used this harness did you get instruction on wich wire are for what speaker since ********s wires are not the same colors as factory. I think I have them right since the balance does work correctly. I also switched the rca jacks and had rear speakers and not front.
12-29-2012, 06:16 PM | #2 |
CAROMARO
Nobody?
12-29-2012, 06:24 PM | #3 |
Drives: 2015 ZO6 3LZ Stage 2 A8 Join Date: Nov 2010
Can u post pics of how you got it wired? Might be able to help you but need to see.
12-29-2012, 07:43 PM | #4 |
CAROMARO
I used the wiring info from the StIcky wiring and electronics thread at the top of this page. I matched the wires from the factory harness connection to the ******** harness connection. The thread just really let me know what color wires were pos. and neg. To dark to take pics tonight I will try in the morning. I am 99% sure I have the wires right since the fade and balance worked right. Just don't know if the rear channel on the amp is bad. It is a brand new amp.
12-29-2012, 08:00 PM | #5 |
Drives: 2011 RJT Camaro LT2 RS auto shift Join Date: Dec 2011
What amp do you have?
Caddy
12-29-2012, 08:04 PM | #6 |
i dont know if this will help since he has a zl1 with the ba system but read this thread. He didnt have any sound to his rear speakers. I think it was something with the harness
http://www.camaro5.com/forums/showthread.php?t=267771 hope it helps also try to contact ******** |
12-29-2012, 08:17 PM | #7 |
CAROMARO
Thanks ******** is closed till Monday.
12-30-2012, 09:40 AM | #8 |
CAROMARO
I have the rockford fosgate r250-4.
12-30-2012, 10:45 AM | #9 |
CAROMARO
So I did some troubleshooting this morning hooked everything back up and it works good for a few minutes then the rear speakers go out. So I switched the channels and it worked a few minutes then one front went out then the next. I am figuring its a bad amp.
12-30-2012, 08:21 PM | #10 |
CAROMARO
12-31-2012, 01:36 PM | #11 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
If it works and the goes out, I'd suspect the amp too.
12-31-2012, 01:57 PM | #12 |
Drives: 2011 2SS IOM Vert Join Date: Aug 2009
Perhaps it is going into protect, are you using gli's? Also tell me about the amp, is it brand new? Just need more info. Also, do you know if you might have pinched any of the cables during installation?
12-31-2012, 09:11 PM | #13 | |
CAROMARO
Steve I received your e-mail and will try your recommendations tomorrow. Thanks for the help. |
Thread Tools | |
