Old 10-10-2011, 01:57 PM   #1
paultheman2007
SWFLGENS
paultheman2007's Avatar
Drives: 2011 Camaro 1SS
Cam for a l99
okay Guys I might be Posting in the Wrong Section and I want to know what is the best Cam to get for a l99 ss and is it hard to put in also, what should i but with the cam
SWFLGENS on facebook.
paultheman2007 is offline   Reply With Quote
Old 10-10-2011, 02:00 PM   #2
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
If you are going to cam it. I would consider doing the ls3 conversion as well. Vvt cam. Bleh...
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 10-10-2011, 02:19 PM   #3
stso634
stso634's Avatar
Drives: 2010 Camaro 2SS/RS
If you are asking how hard the install is, you really need to talk with some of the Forum Sponsors about a cam install. They will ask lots of questions about your driving habits, then make a suggestion for a cam, heads, torque convetor. A lot of different things go into making the correct cam decision and it is different for most people.
Being in Florida, you should have no problem finding a good shop to do this mod.
stso634 is offline   Reply With Quote
Old 10-10-2011, 02:38 PM   #4
brantley847
v It bites.
brantley847's Avatar
Drives: 2011 IBM 2SS/RS
You have a ton of excellent shops at your disposal between Tampa / Miami. I would not do this install alone unless you have a set up similar to a shop in your garage.
You have the option between a VVT cam (I would still recommend deleting your AFM/DOD even with a VVT) or going the route of an LS3 conversion. The conversion is very expensive, but seems to be a tried method that is reliable... every conversion I have seen AFTER install and tune pushes close to 4k. I haven't seen any reported failures from a VVT cam except where the install wasn't too blame...
The VVT cams seem to be newer technology, and many installers here in Orlando do not want to deal with the tune portion of it. VVT is much cheaper and can produce very, VERY GOOD numbers.
2011 2SS/RS
Performance: 439 RWHP: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit.
brantley847 is offline   Reply With Quote
Old 10-10-2011, 04:50 PM   #5
BLACK10
BLACK10's Avatar
Lethal racing in south Louisiana
Old 10-10-2011, 08:14 PM   #6
Lethal Racing
Lethal Racing's Avatar
Drives: LSx Performance Specialist
Paul there are a lot of variable to consider when installing a cam. Luckily for you there are a lot of vendors here that can point you in the right direction. Feel free to give me a call and I'll be happy to help you out or design a cam for you.
Shawn
Lethal Racing is offline   Reply With Quote
L99 Cam, selecting??? siriusdish Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 54 07-09-2011 12:30 PM
FS stock cam and lifters from L99 Darth_Emma V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 0 04-17-2011 02:23 PM
cam sensor part number needed for LS3 cam swap on L99 NEGXXIS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 0 12-12-2010 11:21 AM
L99: Cam or Forced Induction? AdamCzap Forced Induction - V8 7 08-25-2010 08:09 AM
L99 TVS 1900 + Cam Dyno #'s ARE IN pharmd Forced Induction - V8 35 09-07-2009 04:36 AM
