Old 12-22-2011, 10:43 AM   #1
tadams72
When is enough ever...
tadams72's Avatar
Drives: 2006 Silverado 2500HD CC/SB LBZ
Location: Residence: Chula Vista, CA Home: Billings, MT
LS3 Clutch Replacement
Ok, didn't see a DIY for clutch replacement in here so going to put it out there. Starting to pull my 2011 apart today to install a new clutch (RPS twin disc carbon/Street Slayer).
So looking for some tips for the transmission removal and clutch replacement. If you have any, let me know. Thanks.
The Project: 2011 Camaro 2SS/RS (ERL 427 Superdeck NA Monster)
"Just like farmer engineering. Find the weak link and fix it, then find the next one." Salt Cat Racing
tadams72 is offline   Reply With Quote
Old 12-22-2011, 11:12 AM   #2
1stGM
1stGM's Avatar
Drives: IOM 2SS/RS M6
Going to start on mine next week.... I havent found any diys either.... Ill figure it out as I go... I dont think it will be a big deal...
1stGM is offline   Reply With Quote
Old 12-22-2011, 02:00 PM   #3
tadams72
tadams72's Avatar
No it shouldn't be but rather learn from someone elses trial and error than my own. We shall see I guess. Also would help to get some of the torque specs on everything and if any of these bolts are the torque to yield throw-aways.
Old 12-24-2011, 04:57 PM   #4
ChargedCamaro
ChargedCamaro's Avatar
Drives: Twin Turbo LSX Camaro
I just did mine, it wasnt to bad at all. If you have any questions let me know. Im in SD too
ChargedCamaro is offline   Reply With Quote
Old 12-24-2011, 07:30 PM   #5
tadams72
tadams72's Avatar
Transmission is Out!
Good to know. Transmission came out today without too much difficulty. Wondering about how it will be going back in. How was bleeding the clutch? Looks like a tight fit to the bleed line. Any hang-ups?
Old 12-24-2011, 08:01 PM   #6
Bodih
I Got My Orange Crush
Bodih's Avatar
Drives: it like I stoles it...
My love is in league with the freeway. Its passion will ride, as the cities fly by, and the tail-lights dissolve in the coming of night. And the questions in thousands take flight ~Robert Plant - Big Log~
Bodih is offline   Reply With Quote
Old 12-24-2011, 08:43 PM   #7
bn1651
bn1651's Avatar
Drives: 2SS/RS ,6sp
Please take lots of pics, maybe make your own diy that way those of us that have to do it in the future can have an easier go at it. someones always gotta be first after all.
bn1651 is offline   Reply With Quote
Old 12-25-2011, 01:02 PM   #8
ChargedCamaro
It was a little tight bleeding it, I just used a 9mm open end flexable angle wrench and worked like a champ. Could also use a socket and wobble but would leak a little fluid, are you changing the slave out?
Old 12-25-2011, 01:12 PM   #9
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
I suggest getting the Tick Performance remote speed bleeder while the trans is out. Will make it easy to flush the fluid in the future as well.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 12-25-2011, 01:17 PM   #10
tadams72
tadams72's Avatar
No, using the same slave but since it was disconnected to remove the transmission going to need to be bled. Was going to purchase that remote bleeder line from Tick Performance but they are out of stock until next month so going to do it the harder way I guess.
Old 12-25-2011, 01:19 PM   #11
tadams72
tadams72's Avatar
Yeah I got a little ahead of myself and did not snap many photos to this point. I'll see if I can get enough putting it back together to make a DIY. Not real good about stopping to take photos and notes though so we'll se how it goes.
Old 12-25-2011, 01:28 PM   #12
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
i just blew my slave cylinder in my twin disc, i would def consider upgrading this as it will leave you starnded and you will have to reove everything again if it blows..http://www.camaro5.com/forums/showth...age=18...video 2
mikepage0007 is offline   Reply With Quote
Old 12-25-2011, 04:57 PM   #13
tadams72
tadams72's Avatar
Read your other post. Got any pics to show the carnage and what might have caused the failure? Not going to upgrade the slave at the moment but will look into options for the future if necessary. Expecting to pull the tranny out again down the road for some RPM transmission upgrades anyhow.
I really want the manual to work. Lots of guys shifting over to the 4L80E and such but I bought a manual car to be more "connected" to the road/track. We'll see how it goes from here.
Old 12-25-2011, 05:22 PM   #14
mikepage0007
Drives: 2010 camaro
won,t tear it down for a week or 2, i have a 427 lsx and 4l80 already here, was gonna tear down in 2 weeks ...so that date just got moved up...no since in fixing it now...but i,m 99% sure the slave gave out..also when talking to my mech he said he has seen it b4 on hard shifting , so he is not surprised...i only wish i had known b4 i installed the clutch...this would suck 200 miles from home...as i go to pony wars and run at track......thought your post was a good place to let others know, since it seems they have upgraded this part for something a little stronger...
Clutch replacement V6 sparaz V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 58 10-21-2015 03:45 PM
Clutch replacement costs? - Aisin Warner AY6 MT rolnslo Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 10 04-23-2014 06:08 AM
Street Slayer Ultra Performance Clutches Data/Info Hendrix-Engineering V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 64 07-27-2012 10:08 PM
Clutch Problem phenixdragon Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 20 08-22-2010 10:51 AM
Does anyone know any companies that stock the LS9 clutch that works for the LS3? Mindz V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 8 04-19-2010 07:26 PM
