11-12-2013, 01:49 PM | #1 |
Building Turbo Kit this winter
What is a good turbo for a single front mount for my 2010 v6?
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/ |
11-12-2013, 04:02 PM | #2 |
Red Brick of Vengeance!
Drives: 12 Second Brick Join Date: Jun 2009
Personally... i'ld worry more about the tune....
11-12-2013, 04:58 PM | #3 |
Drives: Black 2011 Camaro Ls Join Date: Mar 2011
This. I've also been trying to build my own single front mount. I know how to build it and everything I need just cannot find anyone to tune it. I've emailed trifecta and some of their vendors and a response is hard to come by.
11-12-2013, 05:06 PM | #4 |
Drives: 2011 CGM Camaro LS A6 Join Date: Jan 2011
The tune is the most important part. Everything will be for naught if the tune isn't perfect. I'd get that figured out first before doing anything else. If I had more funds, this is the route I'd be going. I have dyno tuning 2 hours from me so that's figured out. If you don't have this luxury don't do it |
11-12-2013, 06:05 PM | #5 |
looks like you got headers? Why go turbo then, unless it's rear mount. But it is all in the tune.
11-12-2013, 08:16 PM | #6 |
Always bet on Black
Drives: 2011 turbo LS, 2012 f 150, Join Date: Nov 2010
Tuning is only a issue if you don't know where to look as far as trifecta they will tune any turbo that is not rx brand. Ipf may also tune a turbo and there are a few more as well like madtuner or Ion(who will dyno tune your car the only problem is you have to bring it to him). The only problem is dyno tuning were logs will have to be sent back and forth making it a pain and time consuming.
11-12-2013, 08:58 PM | #7 | |
11-12-2013, 09:06 PM | #8 | |
Always bet on Black
Best way to get a response from ion is to call he a one operation but well worth the wait ask Rob21 with the llt top mount from rx. Had him also check my tune which was spot on. I want disagree it hard to get response from Vince. Ipf to my knowlegde will tune turbos from a few of my email conversation with them. |
11-12-2013, 09:46 PM | #9 | |
11-13-2013, 03:15 AM | #10 |
Vince said he could tune if. but if not I have a local dyno shop that can do it.
11-13-2013, 09:09 AM | #11 | |
Always bet on Black
Yes look like he change his site his number was once listed a few months back. send a fax with your number and a question maybe you will get a faster response. |
11-13-2013, 01:21 PM | #12 |
I just need turbo specs
11-13-2013, 01:52 PM | #13 |
Always bet on Black
what brand?
mine is a comp turbo ct4 6062 with a .82ar with t3 flange |
11-13-2013, 07:12 PM | #14 |
Don't matter just don't want junk and perfer to be a ball bearing turbo.
