11-27-2014, 01:39 AM | #1 |
Drives: 16' Supercharged 1SS Join Date: Apr 2014
When to start changing belts?
My Camaro is at 12k miles now and I feel like it's making a weird noise from under the hood that has to do with the belts, but I'm not sure. It's sorta like a clicking noise, I don't know how to explain it at all.
I do need my oil changed as it's at 24% and I'm going in to get my 12,500 service done next week, but I wanted to hear what you guys have to say? |
11-27-2014, 05:36 AM | #2 |
Tell them your issue and have them check your belt tension while they're doing the service (may be part of it anyway).
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
11-27-2014, 05:55 AM | #3 |
Drives: 2012 CAMARO 2SS 45TH,L99 Join Date: Oct 2014
My guess is that the noise you hear is not the belt and if so the belt just needs an idler adjustment. The belt is supposed to be good for a 100K miles.
11-27-2014, 10:05 AM | #4 |
Drives: 2014 2SS RS LS3 Join Date: Oct 2012
the clicking noise you are hearing, is most likely the VVT (variable valve timing), and is very noticeable in tunnels, drive-thrus, and anything that the noise can bounce off.
Thank our veterans for peace today, Support our troops for peace tomorrow. RIP Dad, 1962-2012 SYOTOS |
11-27-2014, 01:01 PM | #5 |
I can hear it more at idle, rather than driving or when going slower, it's very weird.
11-27-2014, 01:41 PM | #6 |
Drives: 2015 2SS/RS Join Date: Apr 2012
The high pressure fuel pump at the left rear of the engine makes a very audible clicking/chirping noise as it is generating hundreds of pounds of fuel pressure for the direct injection system.
2015 Camaro 2SS/RS SIM
2016 Jeep Wrangler 2DR Willys Wheeler 1993 C1500 Single Cab Stepside 5.3L LS Swap |
11-27-2014, 07:53 PM | #7 |
Drives: 2010 CGM Camaro 2SS/LS3 Join Date: Oct 2013
The belt should be good for a long time. Also i'm not aware of any 12,500 mile maintenance?
2010 2SS
BMR 1" Springs Koni Orange struts/shocks 1LE rear sway bar SRP Racing Pedals Hurst Billet short shifter Square tire/wheel setup Elite Engineering Catch Can Stainless Power longtubes/highflow cats K&N Typhoon CAI RPM Motorsports of Garner, NC dyno tune (421 RWHP) |
11-27-2014, 08:00 PM | #8 |
That clicking noise is very normal. Remember not all camaros are the same, some our louder than others. I thought ti was a lifter noise when I first bought the car as well but if you do a quick search through the threads you'll see for yourself
12-03-2014, 06:07 AM | #9 |
Drives: '13 1LE, '89 Caprice Join Date: Jul 2013
You can use silicone spray to keep the belts quiet and lengthen their life.
12-06-2014, 08:21 PM | #10 |
Drives: 2023 Camaro 1SS Join Date: Apr 2014
The direct injection on these 6's makes for audible ticking at idle and slow speeds. If it's running fine, don't stress out. Ask if everything sounds normal when you take it in for service.
