12-24-2014, 07:58 PM | #1 |
BMBLBLU
Drives: Aqua Blue Metallic 2010 Camaro 1ss Join Date: Jul 2010
Help with stereo build
I will be installing two 1200/1 HD amps, one 600/4 HD amp, two JL 12w7 3 anniversary subs, one Kenwood DNN991HD reciever, Alpine PXA -H800, Alpine RUX-C800 Remote Commander as well as JL Audio ZR650-CSi JL Audio C2-690tx, Kenwood CMOS-320 Multi-Angle Rear View Camera. My car is going through a heart transplant to replace the bottom end of engine as I ripped the snout off the crank. Please let me know what you think and any suggestions on my build. I am sorry I placed this in another post but would like to know if anyone has this similar type stereo equipment build.
Steve
12-25-2014, 01:52 AM | #2 |
Drives: 2010 camaro 2ss l99 Join Date: Dec 2014
Are you dead set on jl? They are overpriced like crazy imo. But if you were to build that system what sI've box are you going to use?
12-25-2014, 11:01 AM | #3 |
BMBLBLU
I was thinking about either a custom box built by a shop in Virginia or I was going to call and get the ******** box as I had called them a while back and they said they can build the box to accommodate the w7.
Steve
12-25-2014, 11:09 AM | #4 |
Drives: 2010 Yellow 2SS, 2011 CG 1LT IPF SC Join Date: May 2011
I dont know if you thought of what type of power you are going to be pulling but you might want to think about adding something like this so you dont get any power fade.
http://www.ebay.com/itm/Kinetik-KHC1...-/351057240222 |
12-25-2014, 11:22 AM | #5 |
BMBLBLU
http://www.ebay.com/itm/Kinetik-KHC1...-/351057240222 Would you say to replace the battery I have now (ADM Advance Auto Battery) with the one you are suggesting or add this to the build? Your thoughts on that?????
12-25-2014, 04:51 PM | #6 |
Just added it with the battery you have. I have the power cable off this running to a power disterbution block. Off the block I ran a power cable to each of my amps and never have any power fade to any of the cars electronics.
12-25-2014, 06:20 PM | #7 |
BMBLBLU
Thank you! I will see what I have to do to add this so my stereo build is as good as my engine build.
Steve
12-26-2014, 05:01 PM | #8 |
BMBLBLU
I know this is the Holiday season but can people with a similar build touch on this thread?
Steve
12-27-2014, 12:28 PM | #9 |
Drives: burnt orange Join Date: Jul 2014
do you already have all this equipment? what shop is build the enclosure for you?
12-27-2014, 03:59 PM | #10 |
BMBLBLU
Yes I have already purchased the equipment listed in the first Post. I don't know just yet whom I am going to get to build the box. I have thought about a box by sub thump but at this time dont know if they are the ones I will get it from. Do you have any suggestions as i see you are in MD as well?
12-30-2014, 05:55 PM | #11 |
BMBLBLU
Any suggestions on a good box builder for the two jlw7 12 in woofers for my camaro in Maryland or Northern Va
12-30-2014, 11:26 PM | #12 |
Drives: 2010 2SS/RS Join Date: May 2010
******** period! Excellent quality. Steve is the best at what he does and totally supports our Gen5 community! Call him.
LME built LSX427 w/t all Callies internals| AGP 65/65 TT | Holley Sniper Intake | Brodix BR3/LME custom ported | LME custom cam | Pro EFI 112 ECU | ID-1700x | NGK BR7EF | AGP's-Fore Triple Fuel pump | Monster LT1-S Triple | ZL1 3.23 diff, CF driveshaft, ZL1 axles | Hurst Line Lock | MGW Retro Short Throw | Pfadt solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Ground Control camber/caster plates | Accelerated Racing Solutions tuned| God is too good! I don't deserve it, but I sure will accept it!!! |
12-30-2014, 11:49 PM | #13 |
guess you won't be needing drop springs.
12-31-2014, 06:26 PM | #14 |
Drives: 2010 zr1 Camaro 2011 vert Join Date: Apr 2013
Give me a call and i will give you a box design that is seldom used but would be great for you to save some trunk.I know we have every independent rear passenger car record but i actually know more about car stereo than i do making IRS work lol.Thomas 980 521 0722..call anytime
Thread Tools | |
