Old 01-20-2013, 05:50 PM   #1
AKA-51
Drives: Ellie
Razzi V-6 front Lip splitter. Glue or 3m tape.
Do you have to use the Glue in this kit to install Razzi front lip spoiler ? I was wondering if you could use the 3m tape instead..Im not really a fan of the glue just in-case i change my mind and wont to take it off
AKA-51 is offline   Reply With Quote
Old 01-20-2013, 11:07 PM   #2
camaro_RS
Emerald Coast Camaros
camaro_RS's Avatar
Drives: A lot of show, not much go.
I'm pretty sure it was the tape used to install mine. Works good.
-White Mary Jane....build thread [COTW 6/11/12] :
camaro_RS is offline   Reply With Quote
Old 01-20-2013, 11:13 PM   #3
zkdreads
zkdreads's Avatar
Drives: 2010 Camaro LS V6
3m AND find some small bolts if you feel you need it to be more secure
C-LO or Sonic
"Without Struggle there is no progress"
I am your best nightmare!
zkdreads is offline   Reply With Quote
Old 01-20-2013, 11:16 PM   #4
AKA-51
Drives: Ellie
so you didnt use glue at all???
Old 01-21-2013, 06:50 AM   #5
scruffyluv
CB5thGEN
Drives: 2013 2SS/RS BRM 1LE, 05 Trailblazer
dont glue,. use the 3mm and rivits if you feel the tape isnt secure enough. and.. if you have the side skirts... be wary of portable dynos... we were on one last summer and it ripped my drivers skirt right off.. not a happy camper
scruffyluv is offline   Reply With Quote
Old 01-21-2013, 07:24 AM   #6
06_warrior
06_warrior's Avatar
Drives: 2012 1SS LS3 M6 black on black :)
Don't use glue. If and when you ever decide to remove it the splitter it will damage and possible pull the paint off. You'll be kicking yourself for using glue.
06_warrior is offline   Reply With Quote
Old 01-21-2013, 08:55 AM   #7
AKA-51
Drives: Ellie
thanks
thanks bud thats what i wanted to know!!!
Old 01-21-2013, 09:03 AM   #8
chevy 3
NEcamaro5
chevy 3's Avatar
Drives: Black 2ss rs 1LE
Dam strait DON'T use the glue. I did and then hit a 2x4 on the highway at 80 and it shattered the driver side lower razzy. Then I wanted to fix it and I can't get the pieces off the nose. So now I have a new nose and a crappy spare
chevy 3 is offline   Reply With Quote
Old 01-21-2013, 09:06 AM   #9
AKA-51
Drives: Ellie
yeah i didnt like the idea of the glue at all..
Old 01-21-2013, 09:08 AM   #10
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
most of those adhesives will eat through clear coat and glue, so, not a good idea. I did it on a car that we were actually coming back and using filler to blend the ground effects into the rear bumper, so it was definitely permanent. Anything else, use tape, and rivets if desired
Old 03-29-2013, 03:45 PM   #11
AKA-22
AKA-22's Avatar
Drives: ELLE-1
these L shaped brackets ,,do i use all four for the two front wheels????i would assume that you would only use the two smaller ones,,,help!!
AKA-22 is offline   Reply With Quote
Old 03-29-2013, 04:32 PM   #12
KMAN114
Drives: 2010 Black LS
I plan on mounting mine with the brackets and then making something to attach the nose of it to the two bolts under the front bumper. I have to take mine off when I starts to snow so it doesn't turn into a plow
KMAN114 is offline   Reply With Quote
