03-03-2014, 10:26 PM | #1 |
Drives: 2010 Silver Ice Metallic 1LT Camaro Join Date: Aug 2010
70k miles. What should be done...
Hey ladies and gentlemen, my Camaro is creeping up on 70k miles. I do oil changes roughly every 3500-5000 miles. Full synthetic and ill also use one of those fuel system cleaners that you pour into the gas. But ive seen people say that other things should be changed. Ive checked the manual and everything seems fine but maybe you all could give me some reccomendations as to what you would do/reccomend. The brakes were already done, intake cleaned etc. im talking more along the lines of brake fluid and things like that. Should i change all the fluids or leave everything? It was inspected january of this year. Ive seen people on here say theyve already changed brake fluids and fuel lines and im just trying to get an idea of whats best to keep thr car running for life. Thanks everyone.
Also need spark plugs, whats best and why?
Current Mods: K&N Air Charger Cold Air Intake, PaceSetter Long Tube Performance Headers, Flowmaster American Thunder Axle Back Exhaust, 20% Tints. Future Mods: HP Tune, Magnaflow Performance Cat Back Exhaust, Painted Stripes, 10% Tints. |
03-03-2014, 10:46 PM | #2 |
Drives: Black ZL1 Join Date: Apr 2013
First, celebrate all the good memories and look forward to another 70k miles worth to come.
Check out Alabama Camaros, for Camaro enthusiasts all around Alabama https://www.facebook.com/groups/1739...group_activity
03-03-2014, 10:54 PM | #3 |
have you replaced all the fluids yet. if not there all very long over due. plugs wires might help. 100,000 is the interval but some have seen improvements buy replacing with same oem wires and plug at 70k.
03-04-2014, 12:23 AM | #4 |
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1 Join Date: Jan 2014
Replace power steering fluid.
03-04-2014, 12:38 AM | #5 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
Spark plugs (the OEM ones are good), cabin filter, I replaced my struts with coilovers.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
03-04-2014, 06:01 PM | #6 |
I havent changed any fluids except for oil. So power steering fluid the cabin air filter and spark plugs should all be done. what brand spark plugs you all recommend? Any better than others? Or they all pretty much the same?
03-04-2014, 06:11 PM | #7 |
along with the rear differential only use OEM AC Delco. your ignition requires the plugs and wires to be within a certain resistance. Aftermarket do not have the same specs so they will work on many vehicles.
03-04-2014, 07:45 PM | #8 |
Dimitri
03-04-2014, 07:48 PM | #9 |
SSmokinJoe
Drives: 2010 SIM 1SS/RS M6 Join Date: Feb 2010
I just had my 75,000 mile service done. They recommend changing rear-diff fluid and cleaning fuel injectors, in addition to oil change.
1SS/RS Silver with Black Rally Stripes.
35% Tint Roto-Fab CAI SLP Loudmouth II Axleback Hurst Shifter R1Concepts Slotted Rotors Hawk Ceramic Brakepads I drive way too fast to worry about my cholesterol. |
