Old 02-14-2020, 01:00 AM   #1
imponte
imponte's Avatar
Drives: '10 Camaro SS
L99 Cylinder 5 misfire problem, please help
Hi. I have an issue. When i drive 3-4 k rpm, CEL light came on for 5-6 second then disappear. The pending code was p0300 random misfire and p0305 cylinder 5 misfire. Replaced spark plug, spark plug wires. Nothing changed. And only first start in the morning, the engine die in 1-2 second after start. But second try it totaly normal. Normal drive is totaly normal. I have a cold air intake with new maf sensor, catless x pipe with long tube headers, custom engine and trans tune.
There is the code:
https://i.hizliresim.com/7QmB7P.png
imponte is offline   Reply With Quote
Old 02-14-2020, 01:46 AM   #2
SSammy
SSammy's Avatar
Drives: 2015 2SS A6 Commemorative Edition
Have you tried swapping coils to see if the cylinder # changed?
SSammy is offline   Reply With Quote
Old 02-14-2020, 02:57 AM   #3
imponte
imponte's Avatar
I'm doing this now. I hope this is the issue.
Old 02-14-2020, 07:16 AM   #4
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
I would check fuel pressure you might have a pump dying. Start then stall the fuel might be bleeding back when the car is off and not getting good prime on first start or low fuel pressure. If it is a random misfire that also leads me towards a fuel issue or vacuum leak
Greenhornet2 is offline   Reply With Quote
Old 02-15-2020, 04:47 AM   #5
imponte
imponte's Avatar
https://i.hizliresim.com/7QmJJN.png
Here is my fuel pressure. It contains wide open throtthle. Max 450 kpa, min 366 kpa. In ignition on 546 kpa. Especially in cold weather like 0 C, car starting but immediatly die. I tried 2-3 times and it run.
Old 02-15-2020, 05:33 AM   #6
imponte
imponte's Avatar
I have long tube headers. The o2 sensor can cause that issue? Maybe they are melting? Or heated issue?
Old 02-15-2020, 07:02 AM   #7
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M
I would suspect the maf sensor if you replaced it and the intake AFTER the car was tuned. The maf is extremely sensitive in these cars.
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq
3rdgen3 is offline   Reply With Quote
Old 02-15-2020, 07:39 AM   #8
imponte
imponte's Avatar
I replaced the maf sensor after tune, but the issue isnt change.
Today i bring the car to a local shop. Read dtc, i have a new code. P1153.. and p0300. P1153 is o2 sensor. Im gonna replace my o2 sensors before the cat. Maybe the all issue is that simple. I drove 50-60 miles and no issue. And of course i changed the coil 5 to 3.
Old 02-20-2020, 05:08 AM   #9
imponte
imponte's Avatar
Update !
My tuner edit his tune and all problems gone. So far so good.. Thank you every one!!
