06-29-2013, 11:16 PM | #1 |
Drives: 2013 ZL1 Join Date: Jun 2013
How does heat affect your performance?
I live in Texas, and lately it has been 105 every damn day. I drive my new ZL1 around in it, and it surely can't be runnin like it could. I attribute alot of the power drain to AC, but I'm hopin that one of you engineering gurus can give some objective info on the power changes with ambient temperature change.
How can it be overcome? Someone once mentioned that if you add a little torco to your fuel it would help. Why? |
06-30-2013, 12:30 AM | #2 |
BAD ZL1
Drives: 2013 VIN 48 Victory Red ZL1! Join Date: Jan 2012
Hot air is less dense than cold air. Imagine a cubic foot of air, there is less (air) in a cubic foot of hot air than a cubic foot of cold air. More mass air flow equals more power, less equals less. As far as overcoming it, mod the car with after market crap. It was 109 here in California today.
06-30-2013, 04:04 AM | #3 |
Untamed Performance EPT
Drives: 2011 2SS Join Date: Aug 2012
There's a sponsor on the forum here that makes a 'superchiller' that lowers your internal air temp close to ambient. look it up, they have a couple you tube videos
Night Fury Cam
Borla LT Headers and Borla Cat Back ATAK 9in. diff with 4.11's, DSS Axles, and Alum Shaft Hurst Short-Shifter; Ideal Garage Master Cylinder H-E Street Slayer Twin Billet Clutch BMR: Adjustable; Trailing Arms, Toe Rods, Extreme Sway Bar. BMR Subframe Bushings. Strange Rear Coilovers and mounts Tuned by Rhino79 |
06-30-2013, 06:04 AM | #4 |
Car Lover By Nature
Drives: 2016 Hyper Blue Metallic SS Join Date: Dec 2009
Talk to Dave. He will take care of your chilling needs.
http://www.camaro5.com/forums/showthread.php?t=255045
06-30-2013, 06:23 AM | #5 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
Adding octane by mixing in some Torco to the fuel won't allow the car to overcome the high intake temps. As others have mentioned adding a superchiller would be the best solution followed by adding a larger heat exchanger with fans and additional coolant capacity to the system with an external reservoir.
06-30-2013, 07:05 AM | #6 |
Drives: 2014 ZL1m6 red hot #569 Join Date: Dec 2009
try the rx/chiller it was the first and is still the best chiller out there. ive had mine on for about a year with no issues and my IAT's stay at least 10 - 20 degrees cooler than outside ambient temps even here in florida. in competitive mode it goes even cooler than 20 degrees.
07-02-2013, 03:34 PM | #7 | ||
Drives: 05 GTO / JETTA TDI Join Date: Jan 2012
07-02-2013, 03:55 PM | #8 |
Drives: ZL1 #529 "El-Jefe" Join Date: Mar 2012
Joe only knows what Rx tells him...
07-02-2013, 06:09 PM | #9 | |
07-02-2013, 06:16 PM | #10 |
HAMMER PILOT
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado Join Date: Nov 2011
My girlfriend likes it hot and says I perform better too!
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
07-02-2013, 06:23 PM | #11 |
Car Lover By Nature
07-02-2013, 06:34 PM | #12 |
07-02-2013, 07:16 PM | #13 |
Drives: 2013 ZL1 Join Date: Nov 2012
In stock form, about how much hp is lost with every 20 degree increase in ambient temp?
07-02-2013, 09:06 PM | #14 |
I know theres 2 sides to every story and thats what happens when partnerships dissolve. I guess that's why it took him another whole year to finally get 1 ready for a car. what do you know anyway all the way out in vegas? oh that's right only what you hear on the forum. |
