Old 10-28-2012, 10:39 AM   #1
02bluess
Camaro Addict
02bluess's Avatar
Drives: 2014 Camaro ZL1 SIM A6
ECS Base Kit + ECS Big Blower Cam + RPM 4L80e = 10.46 @ 134 (4200lb+ raceweight)
Copied from the Drag Racing section... also included the timeslip below for those that were interested in the splits
Been a long time coming, but finally had a chance to get out today and take advantage of some good ol' Illinois 'mine shaft' air with the new setup. Read about it all the time on the east coast, but I've never had a chance to race in -296 DA air before
Things didn't start well... found out when I got to the track that it was 'Diesel Drag Day' - which meant 100+ knobby tired, 4x4 diesels from across the Midwest were there to tear up the track.
Made 6 passes total... wasn't able to make a clean pass the first 5; best was an 11.0 @ 132 on a 1.98 60' (car typically 60's in the 1.6 range with the new stall). Didn't have high hopes for the last pass...
Lucked out and they re-prepped the track right before they sent my lane through... I had been trying everything to 60' without spinning, but for this pass I figured to hell with it... knew I needed to head out after this pass so I just decided to go for it. Footbraked to 2800 and let it rip... flashed to 3800rpm and still spun a little out of the hole, but nothing like the earlier runs. Car was loose on the big end (by this time I was running 17psi in the DR's trying to get some traction) but was able to steer through it and finally run a decent time.
Car was full weight - absolutely zero weight reduction. Last time at the scales it weighed in at 4200lbs with me in it and 1/4 tank of gas. Ran today with 1/3 tank, so if anything was a little heavier than usual.
Big thanks to Chris, Doug, Tommy, and the guys at ECS, as well as Rodney, Kenny, TJ, Todd, and the guys at RPM!! Car performed flawlessly once I was finally able to get some traction
As soon as my wallet recovers from the past few months, I'll (hopefully) continue to move towards my ultimate goal of a high-9 sec full-weight street car
Paul...
2014 Camaro ZL1 SIM A6: Rotofab, VMax TB, 22% Lower Pulley, Stainless Power 1 7/8, Cat Delete, ID850s, DSteck Flex Fuel Kit, DSteck Supplemental Fuel Pump, DSteck E85 Tune
Best Timeslip: TBD
02bluess is offline   Reply With Quote
Old 10-28-2012, 05:03 PM   #2
MANNYS2SS/RS
MANNYS2SS/RS's Avatar
Drives: 2010 Camaro 2SS/RS,LS3
Congrat's
LS-3, ProCharger D1SC
665. rwhp /562. rwtq @ 9.3 psi
MANNYS2SS/RS is offline   Reply With Quote
Old 10-28-2012, 05:36 PM   #3
VanquisherSS
Hasbin of Stock Bottom HP
Drives: CTS-V Coupe, 04 TT Viper
Nice man!!! Good runs I just got my ECS kit on and I'm preparing mine as well. Hopefully I can run good times like this.
VanquisherSS is offline   Reply With Quote
Old 10-28-2012, 06:22 PM   #4
BrokenNut
BrokenNut's Avatar
Drives: GM of course
Great to here!
"Lessons in life are expensive for beginners"
BrokenNut is offline   Reply With Quote
Old 10-28-2012, 09:48 PM   #5
02bluess
Camaro Addict
02bluess's Avatar
Thanks everyone! Really can't say enough about the ECS/RPM setup... driven 140 miles to the track, ran it hard, then turned around and drove 140 miles home. Can't beat that
Saw your build results the other day, your car's going to be a monster!!
Paul...
Best Timeslip: TBD
Old 10-28-2012, 10:58 PM   #6
VanquisherSS
Paul...
Paul,
What are you running rim/tire wise? Any suspension mods?
Old 10-28-2012, 11:00 PM   #7
congrats, awesome time
Old 10-29-2012, 07:56 AM   #8
02bluess
Camaro Addict
02bluess's Avatar
Paul,
18x9.5" ZR1 Replicas with 305/45/18 Nitto NT05R's
Pfadt Trailing Arms and Toe Rods (non-adjustable), Pfadt Sport Sway Bars (Front/Rear), Pfadt Drop Springs
Best Timeslip: TBD
Old 10-29-2012, 07:59 AM   #9
McBeevee
220/221 whatever it takes
McBeevee's Avatar
Drives: See sig....
Very nice....congrats!
Brent
2022 BMW X5 M50i
2022 Ram TRX
2021 GT500 CFHP
2016 Challenger Hellcat A8 1058whp/898wtq
1970 Chevelle SS396 4spd
McBeevee is offline   Reply With Quote
Old 10-29-2012, 08:13 AM   #10
Matt @ RX
Guest
Posts: n/a
Congrats Paul glad to see that thing moving out!
Old 10-29-2012, 10:42 AM   #11
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Great work! Looks like a really fun build!
Old 10-29-2012, 11:18 AM   #12
02bluess
Camaro Addict
02bluess's Avatar
Hey, thanks Matt! You should get a lot of the credit, too... you played a big hand in helping me spec everything out!! Can't wait to see your car get down the track!!!
Paul...
Best Timeslip: TBD
Old 10-29-2012, 11:20 AM   #13
02bluess
Camaro Addict
02bluess's Avatar
Thanks guys! It was great hanging with ECS and you guys in Indy at Camaro5Fest!!
Given the 18" DR, I think it's obvious Pfadt stuff works!!
Paul...
Best Timeslip: TBD
