03-17-2015, 11:12 AM | #1 |
Drives: 2015 2SS/RS 1LE Join Date: Jul 2014
Help me choose!
It's FI time! Always exciting but I have a GOOD problem!
I can't choose between these two: - The new Hellion Top Mount TT - The new Procharger i-1 Both are great setups. I don't think I can go wrong. But, some input from the C5 world could go a long way. My goal is to stay around 750 peak RWHP because I don't want to go through the intensity of over-extensive supporting mods. The internals will stay stock (outside of a great cam setup of course). Which one would you guys go with?? Supporting Mod Plans (will happen at the same time as FI install): 2014 1SS/RS/1LE - FI Cam with all the goodies - 850 injectors - LT headers (only necessary on the i-1) - Meth Injection - Boost-A-Pump Thanks for any help guys! Look foward to joining the FI team! -Matt |
03-17-2015, 11:13 AM | #2 |
Oh, and any essential supporting mods I am missing?
03-17-2015, 11:36 AM | #3 | |
Drives: 2012 Camaro 2ss 45th M6 Join Date: Jun 2012
03-17-2015, 11:41 AM | #4 |
Ragtop Rocket!!!
Drives: Black on Black Convertible Join Date: Mar 2013
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package. 744rwhp 727rwtq |
03-17-2015, 12:16 PM | #5 |
That didn't take long! I was waiting for that question.
Short answer... I want to be different. There are nothing but good things to say about the AGP system, but I think the only reason we don't see the same from Hellion is because theirs is brand new. They have the same 'top-mount' system for the Mustang that's been around a good while. Similar reviews to the AGP Camaro kit. Under hood temps is the main concern with top mount twin turbo's. But the room that the LS3 allows is better than most cars (even the mustang with the same system). The mustang crowd hasn't had much complaint with the temps. I'm all about performance, but looks matter too (show is an equal hobby). I think Hellion has both. |
03-17-2015, 12:40 PM | #6 |
Drives: 2016 Z06 Join Date: Mar 2011
Cool to see that you have a reason for going Hellion over AGP. While we may disagree what looks better under the hood I can understand your choice. There is a thread here about a hellion turbo install posted in 2011 so they have been put in Camaros before their new kit.
http://www.camaro5.com/forums/showth...hlight=hellion |
03-17-2015, 12:52 PM | #7 |
AGP kit has a lot more going for it if you really research and look into it IMO. Just the fact that the hellion uses dual 2.5" downpipes is enough reason I wouldn't touch it, let along the heat issues, and welded headers that I would never touch on a street car that sees good mileage.
AGP also comes with BAP and 850cc injectors if you get the fuel kit. Proven to 1400+rwhp. Only kit I know of that has been ran trouble free for 30k+ miles, in hot and cold. AGP also includes catchcan, ceramic coating, and a lot of stuff that many people don't seem to realize. I would call Kevin and he can explain all the differences and advantages.
Nick
Corvette Z06 -1200ish rwhp |
03-17-2015, 01:00 PM | #8 |
2010 transformer
Drives: 2010 ss camaro Join Date: Nov 2014
Agp intercooler and Procharger no spooling instant power and over 150k miles on prochargers
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
03-17-2015, 01:09 PM | #9 |
Over 300k miles on BW turbos, not sure how that applies. The turbos AGP uses are top of the line for reliability and will out torque the I1 all day if you want low end torque.
For 750rwhp you can just bolt on a AGP kit with meth and done. No FI cam, no headers, no heat wrap, no ceramic to add, no upgrading intercooler, no added fuel stuff. 2nd choice IMO would be ECS kit, headers, cam, meth.
Nick
Corvette Z06 -1200ish rwhp Last edited by Unreal; 03-17-2015 at 01:19 PM. |
03-17-2015, 04:55 PM | #10 |
[QUOTE=Unreal;8300338]AGP kit has a lot more going for it if you really research and look into it IMO. Just the fact that the hellion uses dual 2.5" downpipes is enough reason I wouldn't touch it, let along the heat issues, and welded headers that I would never touch on a street car that sees good mileage.
Hellion has a lifetime warranty on all of their piping. I'm sure if AGP came out with system for the Mustang, everyone would be recommending the Hellion kit based on that being the only experience. Hellion's reputation is also top notch (just from the rival world). |
03-17-2015, 05:17 PM | #11 |
Actually, since I own a mustang, I would do the FPC kit any day over the hellion kit. Also would do the JPC kit before the hellion kit too.
If you want to be different and spend $2k+ more for similar results, go for it. I've dealt with top mount turbos before, and never again. If you really want a Hellion kit I would do the bottom mount one that they have had out for awhile now.
Nick
