04-11-2011, 03:00 PM | #1 |
Drives: 2010 Camaro 2LT Black on Black Join Date: Feb 2009
Problems with Driveshaft after Coil-overs install..PLEASE HELP!!
So i just got my V6 camaro out of the garage and finally got to the shop where my coilovers were to be installed. After the install I drove off and everything seemed fine until I really hit the throttle on first gear. This is when I heard a HUGE vibration in the driveshaft area, pretty scary actually.
At first I thought it was the exhaust clips hitting the pavement from how low the car was, but I checked and it definitely wasn't that. I decided to lay off the throttle for a bit as I wasn't sure what the issue was, but the issue only got worse. Eventually, I would get the same horrible vibration and noise when under moderate throttle in second gear, always at the same point in time too, passing the 3000 RPM area. I figured at this point in time is when the torque starts to kick in and the car's rear end tends to dip down a bit, maybe causing some moving part to rub against another. After several hours of diagnostics, the mechanic figured out that the vibration was coming from the driveshaft. He said he had to remove a heat shield to get to it and that one of the bolts in the driveshaft were missing. He said that it must have cracked under pressure and as a result something was loose and would cause this vibration when any pressure was placed on the driveshaft. He replaced the bolt and put the rear stock suspension on (while keeping the aftermarket ones in the front) and the vibration is gone!! THANK GOD!! Now, at this point what I need to figure out is whether this is an issue that was caused by the coilovers. According to the mechanic, the coilovers changed the angle of the driveshaft or something and put more pressure on it when under throttle. I dont know much about this soo im not sure how possible this is. Has anyone heard of this happening? If the issue turns out to not be related to the coilovers then I may just get them replaced (just to be sure), and reinstalled...maybe they were faulty?? And hope that the whole cracked bolt issue was something that happened because of something else....however, I do remember that when the car was raised, one of the rear tires tended to sag about almost 1 inch lower then the others with these coilovers, maybe one of the coilovers where faulty and they caused some sort of imbalance which caused this???? I do recall the guys at alignment complaining that every time they aligned the car, and test drove it and checked it again, it would always shift out of alignment somehow. The coilovers were purchased from someone who said they did not install it on their camaro....not too sure about that right now.
Injen CAI * 12" Fi Q Sub * Zed Audio 1000W amp * Bigworm Smoke out kit * AAC Afterburner Taillights * Lightwurkz Fog light Halos*
04-11-2011, 03:10 PM | #2 |
Drives: Everywhere Join Date: Jun 2008
The 5th gen Camaro has a fixed diff location. Lowering it has zero affect on pinion angle. Have you had the driveshaft off in the past for any reason?
04-11-2011, 03:12 PM | #3 |
Drives: 2010 2SS/RS ; 1970 Firebird Formula Join Date: Jan 2010
I seem to recall a thread from months ago about breaking driveshaft bolts. Do a search.
Should not be related to the coilovers. |
04-11-2011, 03:13 PM | #4 |
no, I havent touched the driveshaft at all! This is the first mod ive really done after my CAI. I just find it so weird how this issue just happened right after the suspension was installed, im talking like minutes after I took it out of the garage I heard this noise, and it only got worse.
Could the driveshaft be affected in anyway from an improper install of the suspension? The rear was lowered almost 1.5" btw.
04-11-2011, 03:18 PM | #5 |
The d/s bolts are one time use and a few people have busted them behind V8s. I don't think there's any reason the shop would have needed to remove the shaft but then again they think your pinion angle changed so.......you never know.
04-11-2011, 03:20 PM | #6 |
I do recall that I did notice a bit of a stronger vibration on the stick shift under certain rpms usually higher rpms. I actually noticed this on the way to the shop. Since it has been a while (4 months) since I have driven the car, I figured it was normal and I was just over reacting..could this be related to the issue?
04-11-2011, 03:21 PM | #7 |
according to the mechanic, the drive shaft was never touched.
04-11-2011, 03:25 PM | #8 |
Maybe just defective bolts or improper torquing at the factory then.
04-11-2011, 03:29 PM | #9 | |
the mechanic mentioned he replaced the bolt, do you think that should be ok, or are there special bolts that go in here that maybe the dealer is better off fixing?
04-11-2011, 03:41 PM | #10 |
I would at least replace it with the proper part.
04-11-2011, 05:59 PM | #11 |
perfect! will do!! thanks to everyone for all the help!! At this point Im just worried about the dealer trying to void my warranty because I put a temporary bolt in the driveshaft until I got it to them.......maybe I should take the bolt out and plead ignorance.....lol anyways, thanks again, you guys are always very helpful!
04-11-2011, 06:58 PM | #12 | ||
For some reason Im not convinced that these coilovers are not in some way to blame for that broken/missing bolt. Unless its pure coincidence....?
04-11-2011, 07:43 PM | #13 |
Drives: own more cars than i can list Join Date: Nov 2010
The Cv would have to real bad for the ride height to make the axle vibrate, i really don't believe it would be an issue. the axles are true CV's so angle should not affect them.
04-12-2011, 10:28 AM | #14 |
Drives: 2008 Z06 Join Date: Apr 2009
my car still vibrates.... dealers dont want to touch my car and i have not found anyone local that can help me. i looked under and all the bolts are there.
my stick also vibrated and created a weird frequency in 5th gear at 55 mph with light throttle, when i let off the throttle is doesnt make the noise. i have changed the shifter from stock to hurst to stock to barton and still does it all the time. i even placed a bunch of dynomat on the stick and tranny connection and still noise. my problems started after camarofest last year after runnin down the track and i got some nasty wheel hop and burned clutch on my last pass. the car was stock with the excption of LT headers. wish i never ran down the track... oh well just waiting for something to break. i changed the trailing arms to BMR and still does it but more a little more pronunced than before. gotten used to it, just part of 545 rwhp i guess.
Similar Threads | ||||
HELP!!! problems with colorshift halo install | silver_bullet | Cosmetics and Lighting Modification Discussions | 1 | 02-25-2011 07:59 AM |
Stall install problems | treedoc2000 | Tuning / Diagnostics -- engine and transmission | 13 | 05-02-2010 10:45 PM |
2 Problems after Airraid install | noisemker | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 33 | 01-10-2010 01:45 PM |
Pedders Xa Coil Over for the Camaro | Info@PeddersUSA.com | Wheels and Tires Talk Sponsored by The Tire Rack | 41 | 07-17-2009 04:44 PM |
Coil Overs or Air Bags? | Bentley78 | Wheels and Tires Talk Sponsored by The Tire Rack | 7 | 04-16-2009 01:12 PM |
