06-08-2012, 12:41 AM | #1 |
Drives: 2012 Chevrolet Camaro 2LT RS Join Date: Apr 2012
Removing gold part of OEM emblem
has anyone removed the gold part of their bowtie to install different color ones? If so how did you remove the gold part of your OEM emblem. I want to install these but don't know how to remove the gold part. http://www.rpidesigns.com/shop/item.aspx?itemid=1727
06-08-2012, 12:43 AM | #2 |
Raised by Wolves
I'm just guessing but don't they just stick on the gold part?
06-08-2012, 12:51 AM | #3 |
it says that they replace the gold part, not overlay
06-08-2012, 01:03 AM | #4 |
Drives: 2011 CGM 1SS L99 Join Date: May 2011
Wouldn't it be easier and cheaper to just buy some vinyl overlays?
06-08-2012, 01:07 AM | #5 |
06-08-2012, 01:18 AM | #6 |
Drives: 2012 1LT BLACK ON BLACK Join Date: Apr 2012
honestly....use plastidip
save yourself 100$
06-08-2012, 01:23 AM | #7 |
06-08-2012, 01:24 AM | #8 |
Ahh gotcha! Have you looked into some custom painted ones. There's a member on here who sells them, i forgot his name. But he does really good custom painted ones. I didn't even know GM sold black oem bowties to replace the gold ones.
06-08-2012, 01:32 AM | #9 |
Great! Let me know when you remember his name. Thank you
06-08-2012, 06:02 AM | #10 |
Drives: 2011 Black LS3 2SS/RS Join Date: Jul 2011
I had black overlays and after a while they started to peel so I had mine painted at the dealership. Much cleaner look and it will last longer than the overlays. Here is the thread with my pics in it. Good luck!!
http://www.camaro5.com/forums/showth...02#post5025402
2011 2SS/RS, Torch Red Bow Ties, 5% Tint, Oracle Side Markers, Forgestar F14's, Pfadt lowering springs, Vararam Intake, VMax Throttle Body, Custom Grind Comp Cam 224/236 114, SLP Under Drive Pulley, Granatelli Wires, Kooks 1 7/8 LTH, Off-road pipes, 3" exhaust, Mike Norris Motorsports Tune 471 RWHP 449 RWTQ! Search for kcsr6 on YouTube for sound clips.
06-08-2012, 06:12 AM | #11 |
Drives: 2010 Camaro 2SS/RS M6 Join Date: Jan 2011
I removed the gold inserts from the bowties by heating them up with a blow dryer. The front one is pretty easy because you can remove the whole assembly from the car, heat it up and push off through the back. The rear one is more complex. You have to drill a small hole in it, heat it up and then use a small screwdriver to pop it out. I removed mine and installed defenderworx flat black ones.
06-08-2012, 06:21 AM | #12 |
Hating prius's since 1997
Drives: 2010 Camaro 2SS/RS (JENNA) Join Date: Apr 2011
Its simple. Take a drill , put in a drill bit. Drill a hole in the center of the bowtie no more than a 1/16th of an inch deep. Take a small pick tool and pop it off. Same as back bowtie.
PIPE
06-08-2012, 06:31 AM | #13 |
Drives: 2012 Camaro SS 45th Convertible Join Date: May 2012
RPI Designs did mine and they are painted CFM. They turned out great!
They will paint them whatever factory paint color you want. They also have black and carbon fiber. |
06-08-2012, 07:07 AM | #14 |
Drives: 1965 Chevelle Malibu Join Date: Jan 2012
You don't have to remove the gold part to plasti dip. You just have to mask it off. I did mine that way, and a number of other people on here have done it that way as well. $134 is a big waste of money if you can get the exact same look for 5 bucks, and honestly, less work. To each their own though.
Thread Tools | |
