Old 02-01-2017, 12:04 PM   #1
Richyz28
Drives: 2010 SS
2010 SS Camaro smoking under boost BAD
Hey,
I have been battling an oil burning issue for awhile now and wondering if anyone else has had the same or similar issues.
Idling the car shows no sign of burning oil
When driving the car seems fine, when you get on it we see a large cloud of smoke from the tail pipes. I have had a compression test / leak down test done and everything came back good. All Cylinders were within 1 number of each other.
I feel like I have really bad blow by when under boost, I am adding 1 qt of oil every 200 miles give or take which leads me to think it's the piston rings.
Any help would be appreciated as I am running out of options, scheduling another leak down test with a local shop that I can trust.
Mods:
Maggie supercharger
Full exhaust / high flow cats
Cam
Catch Can
Innovators west pulleys
50k miles
Tuned
Richyz28 is offline   Reply With Quote
Old 02-01-2017, 02:35 PM   #2
Avenging Orange
Avenging Orange's Avatar
Did you buy it modified? Did a shop do the work or you do it yourself?
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 02-01-2017, 02:39 PM   #3
frenchsquared
frenchsquared's Avatar
Drives: 15 Z28, 01 Corvette, 96 Corvette
Are you sure it is on it, and not off of it? Mine smoked when I came out of boost.
2018 Sierra RCSB | 2015 Z28 Camaro | 1989 B2200 with a 327 | 1996 LT4 Z51 Corvette | 1973 427 Nova
frenchsquared is offline   Reply With Quote
Old 02-01-2017, 03:14 PM   #4
Richyz28
Drives: 2010 SS
I purchased the car with the mods, I had to have the car tuned to because it was running extremely rich.
There is no oil leaking when the car is parked, not sure where it would be leaking onto the exhaust, I did notice last night if I give the car a high rev you get a decent amount of smoke. Still no smoke at idle.
The car only smokes when on throttle and smokes really bad when WOT
Old 02-01-2017, 03:25 PM   #5
cross-bones
Drives: 2012 L99 EU
Do you have aftermarket valve covers?
Camaro SS 2012 A6, Magnacharger TVS2300, LS3 Conversion, JRE Rough Idle Road Race Cam, GMPP CNC ported LS3 Cylinder Heads, Johnson Lifters, CHE Rocker Arms, Roto Fab Air Intake, LPE Twin Fuel Pump, ID850 Injectors, Pfadt Tri-Y Headers, Borla S-Type Exhaust
cross-bones is offline   Reply With Quote
Old 02-01-2017, 03:31 PM   #6
frenchsquared
I cracked the rings in my LS1. Under medium throttle very little smoke. When I came out of boost a cloud over took the car. Looked like it was on fire. Was filling the intake with oil as well. Never leaked a drop when parked. I blew it all out the exhaust.
Old 02-01-2017, 03:34 PM   #7
NicKey
NicKey's Avatar
Drives: Nickey Super Camaro
What are the numbers for the compression and leak-down test and who performed the test?
NicKey is offline   Reply With Quote
Old 02-01-2017, 03:41 PM   #8
JLGO
JLGO's Avatar
Drives: 2015 Camaro SS convertible L99
This symptons are hard to diagnose without taking the head off. It could be a pistons oil control ring, bad valve seals, or a oil seal in the supercharger. You can check valve seals with a vacuum gauge, instructions are included on most vacuum test kits. Also you can look at the plugs for any oil for black cover plugs. If one of the plugs is cover in black suspect an oil control ring. The compression and leak down only pin point compression rings and valves. It doesn't test oil ring.
Since your car is supercharger and has too put more fuel in the combustion chamber it is possible that the oil control rings has carbon on it and is not allowing the oil ring to seal and allows oil to get in the combustion chamber. Most people put seafoam in the cylinder that have the problem. The machine shop that I do business with when I had the same problem told me to put PB blaster on the cylinder at dead bottom center. You have to fill up the cylinder or cylinders with it and leave it for 24 hours. It worked for me.
JLGO is offline   Reply With Quote
Old 02-01-2017, 05:30 PM   #9
Richyz28
Drives: 2010 SS
Sad but I can't remember the exact numbers with the compression test, if i remember correctly it was either 152 or 157 and all cylinders were almost dead on.
Old 02-01-2017, 05:42 PM   #10
Richyz28
Drives: 2010 SS
I will pull the plugs this weekend and see what shows. They are new plugs and only have about 2,400 miles on them if that. I have never done the Seafoam or PB blaster on a cylinder before.
Old 02-01-2017, 05:45 PM   #11
dentnshell
dentnshell's Avatar
Drives: Black 2014 2SS
What kind of catch can? Does it have a check valve? How much oil is it catching?
2014 L99 2SS. 595HP/571ft-lbs
Mods: LSA Conversion 2.5" Upper Pulley, 65# injectors, GPI SS1 Cam, SP Long Tubes, ADM Race Scoop & CAI, NPP exhaust (DIY control), BMR 1" lowering springs, ZL1 Rear Differential / Axles, CF Side Strip / Hood Spear, Tint - Windows / Tails / Sidemarkers, Splash Guards, ADM Boost Gauge, ABL Dashkit, '68 Script Badges, ACS T4 Splitter, ZL1 Rockers from Gary's, Z28 Spoiler, Carbon Fiber Hood Vent, Summer - MRR FS01 Satin Black (10" Front 11" Rear) Winter, pictured-Drag DR 64's Satin Black (9" Front-10" Rear.)
dentnshell is offline   Reply With Quote
Old 02-01-2017, 06:15 PM   #12
Richyz28
Drives: 2010 SS
My catch can does not have a check valve, it's a moroso.
Old 02-01-2017, 06:17 PM   #13
dentnshell
dentnshell's Avatar
How much oil does it catch... How about coolant level in the intercooler? White Smoke? Blue Smoke?
Old 02-01-2017, 06:25 PM   #14
Richyz28
Drives: 2010 SS
Coolant levels are good all the way around I haven't had to add anything.
The catch can shows about 1/2 inch of oil on the clear oil level indicator.
The smoke coming out of the back is more of a grey smoke with maybe a tint of blue.
I know I am burning oil because of the amount I am putting in.
Thanks for the help if you need more info or if I need to check something just ask.
