06-12-2012, 03:46 PM | #1 |
Drives: 2011 imperial blue SS, black 92 RS Join Date: Apr 2011
Timing retard for nitrous?
I have a kit off my old camaro I'm going to install on my 2011 SS, my problem is I don't want to keep the timing retarded the whole time on the account of the nitrous. I've done some searching and the route I'd like to go is using a resistor on the air temp sensor. I'll dial in the necessary retard at the coldest end of the scale, but I need to know what resistance I need to use to trick the computer. I searched and could not find the answer. Any help would be appreciated.
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires. SOLD :(
2000 1500 silverado extra cab SOLD :( 2017 Silverado 5.3 all stock 2004 5.7 GTO 78mm turbo |
06-12-2012, 07:39 PM | #2 |
No one?
06-12-2012, 10:46 PM | #3 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
Owen over at ARD was always a big nitrous guy, could ask him. He had nitrous on his 4th gen Formula and now his silver 5th gen.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
06-12-2012, 11:29 PM | #4 | |
I'm getting ready to start installing it. Wanna have my ducks in a row
06-13-2012, 03:22 PM | #5 |
Writer
I'll ping him. How much you plan to spray? Wet or dry?
PROJECT HEAVY CHEVY
06-13-2012, 03:25 PM | #6 |
100-125hp wet kit.
06-13-2012, 03:50 PM | #7 |
Drives: CGM,twin turbo, cam 2010 SS/RS Join Date: Mar 2011
Camarowguy can you explain more on the resistor On the temp sensor? Ive never heard of that before.
06-13-2012, 04:02 PM | #8 |
The air temp sensor sends a resistance to the ECM depending on what temp it senses. The ECM converts that to a temp. If you jump a resistor (value unknown, what I'm trying to find out) and it tricks the computer into thinking the air temp is really cold....usually below 0 degrees. You install a relay to activate this resistor and in the air temp map at that temp you choose, you set the timing to whatever you need it to be when using nitrous. If I don't get an answer in the next few days, I'll have to just figure it out on my own.
06-13-2012, 04:18 PM | #9 |
I Wanna Go Faster!!
Drives: 2011 2SS Synergy Green M6 Join Date: Apr 2011
This might be a dumb question but why not just buy a timing retard box from made for nitrous from someone like MSD?
Built by Vengeance Racing
9.31@154.81 mph Procharger F1-X RPM Level 7 4L80e + Coan Converter Hendrix 9" Rear Axle + 3.50 Gear ARH 2" LTs+3.5" Exhaust Fore Fuel System, Bogarts + Hoosier Slicks Pfadt Drag Pack Suspension My Build Thread | Best Pass To Date |
06-13-2012, 04:33 PM | #10 |
Cause it costs alot more than a resistor. I'm not rich lol
06-13-2012, 05:53 PM | #11 |
edit.
06-13-2012, 06:20 PM | #12 | |
I would think a Rheostat would work much better than a fixed ohm resistor and you could fine tune it alot better and would be simpler and much less prone to failure. You could even mount it in the cab if you wanted to run the wires. Just a thought I would still just buy a retard box but I also understand where you coming from... |
06-14-2012, 12:49 PM | #13 |
So who all makes a retard box for the new camaro then. I might just have to coin up and do it right. Damnit. Lol
06-14-2012, 05:43 PM | #14 |
I Wanna Go Faster!!
I think the MSD #8625 will work for what you need...I'd give MSD a call and make sure.
Thread Tools | |
