06-07-2017, 12:56 PM | #1 |
Drives: Dusk SE Join Date: Jun 2014
Leave car running
My current job requires me to make frequent stops. I need to leave my car for about 5 minutes before going to my next stop. I want to leave the car running but cant because i dont want to leave it unlocked. Is it possible to exit a running car and lock it? I've tried to lock it with another remote but it just keeps unlocking. I think this is to keep you from locking the keys inside. Is there a setting in the informant system that can be changed to allow a running car be locked?
06-07-2017, 01:12 PM | #2 |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
It's illegal in most states to leave your car running with the keys in it.
06-07-2017, 01:20 PM | #3 | |
Drives: 2015 2LT/RS BVM Join Date: Mar 2015
or, get a beater for work you don't care about. |
06-07-2017, 01:33 PM | #4 |
Drives: 2014 Red Hot LS3 Join Date: Oct 2014
How many frequent stops do you make per shift?
If it is like 15-30, like pizza delivery guys, then I would definitely get a beater. |
06-07-2017, 02:25 PM | #5 |
Drives: 2017 1SS convertible Join Date: Jun 2015
I haven't tried it on my Camaro yet but I frequently leave my GMC and my chevy truck running when I go into a store. I have a quick release on the keychain so I can take the keyfob and lock the doors with it. Works perfect.
Red 2017 Camaro 1SS Convertible
06-07-2017, 03:07 PM | #6 |
376 cubic inches of fun
Why do you want to leave the car running for five minutes or more?
Safety, security, and needless emissions are good reasons to turn it off. |
06-07-2017, 05:26 PM | #7 |
Im in a safe place dont need to worry about it being stolen. It is my DD beater and im just trying to put less stress on the starter
06-07-2017, 05:29 PM | #8 |
Drives: 2011 RS Join Date: Apr 2011
Use the other FOB manually and stick the key in the door handle......
06-07-2017, 06:56 PM | #9 |
Drives: Miss Con Ception Join Date: Aug 2016
You can press and hold the button on the driver's door until it quits arguing.
Or you can open the passenger door and press the electric lock button. With a manual trans the remote won't work with a key in the ignition so make sure you have another key to unlock the door. I don't know if the remote works on an automatic. If it won't lock the car it probably won't unlock it.
2011 1SS/RS LS3 CGM
06-07-2017, 10:25 PM | #10 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
There certainly is a way. My department ride, a Ford F-150, was equipped with a small button that allows me to remove the keys with the engine running, lock the car, and walk away. Most police cars are equipped with that feature, so you can leave the engine running with the emergency lights on, thus not draining the battery. A local auto electronics shop does the install on our UC rides, and I'm sure then would do it for a civilian vehicle too. If someone was to get in the vehicle and try to drive it, the act of stepping on the brake pedal shuts the engine down. Easy peasy......
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
06-08-2017, 12:58 AM | #11 |
"BEASTM*DE"
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S... Dual 10" Kicker Comp S Subs 1200w... |
06-08-2017, 01:21 AM | #12 |
Take the key with you then hit the remote start. Car will lock and be safely waiting for your return.
06-08-2017, 01:44 AM | #13 |
Drives: 2010 Camaro 2SS RS Join Date: May 2017
I want to say inside of your config settings on the radio there is an option to change if the car will lock with the keys still in the ignition. Otherwise I'd say use an extra key to manually lock the door
2010 Camaro 2SS/RS M6. Vararam Street Spec tune intake. Speed Engineering 1-7/8 LTH. Powerbond 25% UDP. Custom camshaft from Powell. .660" dual springs from BTR. Trunnion upgrades. Chromoly pushrods.
Tuned by DynoSteve at RDPStore. |
06-08-2017, 03:26 AM | #14 |
Drives: 2014 Camaro LS / 13 zl1 Join Date: May 2016
There is a setting in your config on your radio to enable you to do this
