Old 01-04-2012, 12:07 PM   #1
gl2filmerguy
gl2filmerguy's Avatar
Drives: 2010 Summit White Camaro SS/RS
AEM Wideband bung location
Those of you running a wideband, where are you mounting the bung for the O2 sensor? I know it has to be mounted at about a 3 O'clock position, I just wants sure in where on the exhaust it was supposed to go. Thanks.
I am here: http://maps.google.com/maps?ll=41.611906,-83.605374
gl2filmerguy is offline   Reply With Quote
Old 01-04-2012, 12:12 PM   #2
ducatisl
Emerald Coast Camaros
ducatisl's Avatar
Drives: 2010 2SS 6m
Location: Fort Walton Beach...surrounded by da** pickup trucks I can't see around!
In the cat delete pipes (between each front and rear O2 sensor as I run 2 WB's), and if you only run one, put it on the driver's side, where 5 and 7 are as they are typically the lean cylinders.
Procharged F1A-94 on a 416 LSA block, Callies/Manley/Scat/Melling/Cloyes/ARP/Ferrea/Landspeed/Hi-Ram/FIC/Tick/Alky/ Strange/QA1/DSS/BMR/RPS/Tilton/GZM/Fore/AEM/ATi/JGS etc., built/tuned by me and Innovative Street Technologies
'Mo's Seemingly Endless Build Thread
ducatisl is offline   Reply With Quote
Old 01-04-2012, 01:35 PM   #3
gl2filmerguy
Thanks
Old 01-04-2012, 01:38 PM   #4
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
if the wideband has a narrow-band output,, i just use one of the original front o2 bungs. i have set them up this way with several different brands of widebands and no issues.
Old 01-04-2012, 03:34 PM   #5
Stingr69
'69 Owned Since '79
Stingr69's Avatar
I put a bung in the side of the exhaust down pipe right after the manifold where it is easy to access from the side of the fender well. Just find a convienient place ahead of the cat and avoid the low side of the pipes where moisture could collect and contaminate the sensor. I can remove the plug and install my sensor just laying on the ground without any jacking.
-Mark.
Old 01-16-2012, 07:49 PM   #6
evilbeef54
tail lights for u
evilbeef54's Avatar
Drives: Bumble Bee 2010 2SS/RS
okay so with a set of kooks LTs withhigh flow cats you just want it anywhere on the drivers side, infront of the cat but preferably not where the pipe is parallel to the ground?
1972 Camaro 350/Muncie M22 - SOLD
1986 Camaro RS - R.I.P.
1994 Camaro Z28 - SOLD
2010 Camaro 2SS/RS RY M6- LOVIN' it
Kooks LT's & HFC's, Flowmaster Single chamber mufflers, C.A.I. Intake, ADM Scoop, Rotofab w/w relocate
Semper Paratus
You have to go out You don't have to come back!!!
evilbeef54 is offline   Reply With Quote
Old 01-16-2012, 10:38 PM   #7
Erik@lashway
Erik@lashway's Avatar
Drives: Camaros, Vettes, Trucks
Mount it as close to the collector as possible without causing interference with any clamps. You also want to ensure that it is not near a possible leak that could open up around a junction or clamp.
Also, to avoid moisture collecting on the sensor itself, you want to mount it just at or slightly above the 3 o'clock position as previously mentioned.
If you have stainless pipes, enjoy drilling that out. Buy a few bits or a badass stepped bit.
lastly, ensure that the welds around the bung are complete. I cannot tell you how many widebands read a few decimals off because of arrant leaks around the sensor.
Erik@Lashway
Ps- and yes, mount BEFORE the cats if possible for the most accurate reading. Also, be sure to apply some anti seize lubricant to the threads of the sensor so you can remove down the road for service or calibration.
Erik@lashway is offline   Reply With Quote
Brand New AEM Gauges For Sale gotpball44 Local Marketplace 0 08-13-2011 06:28 PM
iPhone/iPad tracking your location... Brokinarrow Off-topic Discussions 18 04-28-2011 06:58 AM
AEM CAI Available : Special Paschal Performance V8 Bolt-Ons & Tunes 1 07-08-2010 09:05 AM
