03-14-2022, 09:20 PM | #1 |
Drives: 2010 2SS Join Date: Dec 2020
$220 - 2010 SS Brembo's With PowerSTOP Trackday & Z26 Extreme Pads - SS (NEAR PHILLY)
Selling a set of Brembo's from my 2010 SS along with some very lightly used powerstop rotors and 2 sets of pads (track day and z26 extreme). The calipers could use a rebuild, IMO. Powerstop stainless brake lines are included. Will need a couple of copper washers or to re-use yours.
The rotors and pads have very little use (less than 5k miles). Switched to a different setup so I can have pads for street and track without needing to switch back and forth. The track day pads are NOISY. The Z26 pads are great low dusting street pads. Do not want to ship these rotors due to weight so pick up in Hatboro PA only. Will ship if you don't want the rotors, but at your expense. Last edited by ccss713; 03-14-2022 at 09:34 PM. |
03-15-2022, 08:48 PM | #2 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Would you split the set up? Need a set of rears.
Orange Krush II
03-17-2022, 09:46 PM | #3 |
This has been sold
