Old 08-05-2013, 06:19 PM   #1
steeleshark2
steeleshark2's Avatar
Help!! Drivetrain issue
It started having vibration over 70mph. It gets bad enough to vibrate the rear view mirror at around 78mph. It then lessons a bit but still is very noticeable above 80mph. The vibration is still there when I put the car in neutral between 70 to 80 mph. I also have notice a thumping sound under moderate acceleration (around 5 thumps a second) and stops when I release the gas. Obviously feels like it is in the drive train. The car is not losing traction or even close to losing traction when accelerating. No other unusual noises in any other driving condition. The car is as in my sig but has stock 3.45s in it. What do you think?
Old 08-05-2013, 06:57 PM   #2
serows1
serows1's Avatar
Drives: Blue Ray 2SS
Typically highway vibrations are due to tire/wheel balance issues. When you shifted into neutral you effectively took the drive train out of the picture unless it's a wheel bearing or u-joint issue. Any noises at slow speeds like a creak or squeak that sounds rotational?
Paul
serows1 is offline   Reply With Quote
Old 08-05-2013, 07:09 PM   #3
steeleshark2
Paul
I do have some type of suspension squeak I hear when I go over bumps. Otherwise nothing else. Nothing rotational as far as I can tell.
Old 08-05-2013, 07:15 PM   #4
serows1
serows1's Avatar
Can you tell where the noise is coming from, inside, outside, front, rear, left or right?
Paul
Old 08-05-2013, 07:22 PM   #5
steeleshark2
Sounds like underneath and around the back end of the car. The thump I can feel in the seat and on the arm rest and also sounds like coming from the rear of the car.
Old 08-05-2013, 07:23 PM   #6
serows1
serows1's Avatar
Is it a squeak or a thump?
Old 08-05-2013, 07:34 PM   #7
steeleshark2
When under moderate acceleration, very distinct thumping that you can even feel. The squeak I was talking about going over bumps almost sounds like a squeaking bed with springs.
Old 08-05-2013, 07:37 PM   #8
serows1
serows1's Avatar
The squeak could be the stabilizer links but the thumping might be a tire or wheel. I would start with a road force balance of the wheels and tires then while it's up in the air check the links to see if any of them are loose.
Does it matter if you have a passenger in the front seat?
Paul
Old 08-05-2013, 07:45 PM   #9
steeleshark2
No matter with the passenger. I just went out again to try a little more spirited driving. The thump goes about 4 to 5 times and no more thump while still accelerating. It will come back again if I let off and then re accelerate. I was thinking about the balance. I got my last tires from Discount Tires, so I have lifetime balance. Definitely a good start for the vibration.
Old 08-05-2013, 08:03 PM   #10
serows1
serows1's Avatar
Acceleration usually doesn't have anything to do with a wheel vibration unless your reaching the vibration speed. I would definitely start with a road force balance then see if that takes care of it. While it's up in the air take a look at the drive shaft to any marks or dents, if there are any that could be your issue also.
Good Luck,
Paul
Old 08-05-2013, 08:06 PM   #11
steeleshark2
Thanks Paul. I will let you know what it turns out to be. Hopefully by the end of the week I will have an answer. Thanks again!
Old 08-06-2013, 01:19 AM   #12
Ron66Vette&10SS
Plays with Hot Wheels
Ron66Vette&10SS's Avatar
Drives: '17 Jet Black ZL1
I'd check for loose, bent, or broken bolts at your driveshaft/differential input shaft coupler "donut".
Previous Cars: '78 Z28, '92 Z28, '95 Z28, '85 Corvette, '01 SS, '96 Z28, '04 Z06 Corvette, '10 SS, '13 SS Hot Wheels
Current Cars: '17 ZL1(daily driver), '04 Trailblazer (rain & snow), '66 Corvette (restoring)
Ron66Vette&10SS is offline   Reply With Quote
Old 08-08-2013, 02:18 PM   #13
freedomintheskies
freedomintheskies's Avatar
Drives: 2010 Camaro SS2
Second the driveshaft. A bad universal joint will show similar symptoms. Does it diminish if the clutch pedal is pushed in (or you shift to neutral) at highway speed?
Live in peace but defend it...Embrace it but never take it for granted...
freedomintheskies is offline   Reply With Quote
Old 08-08-2013, 02:26 PM   #14
kelley1996
kelley1996's Avatar
Drives: '10 Camaro 2SS/RS/'17 Scat Pack
I had the same issue with my Trans Am. I thought that when I put it in neutral it was still there. Found out it was the driveshaft. I thought that even with it in neutral at 70 it would stop the vibration.....not true. It was a bad u joint on the input shaft
kelley1996 is offline   Reply With Quote
