Old 03-15-2015, 10:07 PM   #1
Shiftgreen
Shiftgreen's Avatar
Drives: 2014 2SS 1LE AGM
NPP exhaust tip issue.
I'm going to be installing Solo hfc 's hopefully this week. I noticed a while back that my passenger exhaust tips are about a half inch to an inch lower then the driver side exhaust. I thought they were maybe loose but I can't budge them.
I figured while I'm installing the solos I could try and raise the tips to be even again. Has anyone had the same problem, and if so was there an easy DIY fix?
Thanks !
Shiftgreen is offline   Reply With Quote
Old 03-16-2015, 10:25 AM   #2
LuSe4
LuSe4's Avatar
Drives: 2013 Camaro 2SS RS LS3
Sub'd for an answer as mine are off very slightly too.
-2013 Summit White over Inferno Orange 2SS RS-
-2014 White Diamond Silverado Z71 Crew Cab Short Box-
LuSe4 is offline   Reply With Quote
Old 03-16-2015, 10:29 AM   #3
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
You can bend the arm that holds the rubber hangers.
FSP tuned: 377/389
Old 03-16-2015, 12:29 PM   #4
LuSe4
LuSe4's Avatar
Originally Posted by nyrfan View Post
You can bend the arm that hold the rubber hangers.
That is what I was thinking would need to happen, but I haven't looked at it yet. I will when I put on my ZL1 rear diffuser in a few weeks, though. Thanks!
