Old 06-02-2017, 08:26 AM   #1
2013ZL1FUN
2013ZL1FUN's Avatar
Drives: 2013 ZL1 Convertible A6 BRM
Supercharger Replacement Pitfalls for Dealer
It appears that my Supercharger catastrophically failed with no audible warning. It was discovered when I took the car in for some issues that I encountered while driving: runs on less than 8 cylinders, stabilitrac warning, erratic (automatic trans) downshifts while in drive, exhaust baffles appear open all the time. This cars is 14 days away (June 14th) from being out of 3 yr/ 36k warranty. I want the dealer to "nail" this repair before I am in the power-train only warranty ( I didn't buy any additional warranty that I was offered due to me finding out that it didn't cover "vert" issues that are well known, of course not). Are there certain things I can tell this dealer (hints, if you will) so that they have an easy time with this. I don't believe they do alot of ZL1 repairs. It seems like I have heard of windshields being broken during this procedure or am I thinking of something else? Any advice would be helpful. Thanks in advance.
2013 ZL1 CONVERTIBLE BRM A6
OHIO
2013ZL1FUN is offline   Reply With Quote
Old 06-02-2017, 05:04 PM   #2
gbu27
Drives: 2013 ZL1
Supercharger has a special warranty for 100,000 miles/ 10 years
gbu27 is offline   Reply With Quote
Old 06-02-2017, 05:07 PM   #3
RLHMARINES
1st Civ. Div.
RLHMARINES's Avatar
Drives: Camaroless for now...RIP "Big SexZ"
This^^^^^^
Have them check your magneride shocks for leaks since that will be the most expensive line item to replace but definitely have them inspect your top for wear while you have it there.
The new Chevy PP covers more items including the shocks that was not covered with the old PP from a few years ago. You may want to look into it while you still have time left on your bumper to bumper warranty.
Swift....Silent....Deadly
RLHMARINES is offline   Reply With Quote
Old 06-03-2017, 11:47 AM   #4
Synner
Drives: cars
If you need to advise a dealer on how to do factory servicing of an engine then the best advice would be for you and not them: tow it to another dealer. If you have issues directly after the repair and they're clearly due to the work they just did then they should still cover it if you have a good dealer. Get it and drive it a lot to ensure all is well after getting it back if it's the time part of the warranty that will expire.
I would be asking did the engine ingest any blown up supercharger bits since you didn't say how it failed. Inspect the oil for metal shavings when drained. I would also cut open the oil filter and look for metal shavings.
Old 06-03-2017, 01:08 PM   #5
2013ZL1FUN
2013ZL1FUN's Avatar
I suppose I was just looking for guidance as to what needs monitored for these repairs. I do have confidence in them. It's just so easy for GM to not want anything performed and run me out of warranty.
OHIO
Old 06-03-2017, 01:28 PM   #6
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
I would ask to be there when they remove the Supercharger so you can inspect with them the rotors, and potentially remove the snout and inspect so you are aware of what failed. Make sure they follow the TSB for removal which lowers the cradle for rear access to bolts vs drilling, If they are moving over the old fuel rail make sure they replace the injector O rings top and bottom, (They cannot be reused). Also make sure if the new SC does not have the Post for your SC red cover that they remove all from the old and reattach.
By the way when you said catastrophically failed what does that mean, locked up? If so you would have known as there would have been a heck of a whine coming from the Serp belt and one heck of a smell as it burned.
ZMEnow is offline   Reply With Quote
Old 06-28-2017, 03:17 PM   #7
seamag
seamag's Avatar
Drives: 2015 zl1
Extended supercharger warranty
Any place I can find the extended supercharger warranty in writing? thanks
seamag is offline   Reply With Quote
Old 06-28-2017, 06:53 PM   #8
ZMEnow
Did you try Google?
http://forumfoundrycdn.com/nickj/aut...erCoverage.pdf
Old 06-28-2017, 07:01 PM   #9
HDRDTD
Originally Posted by ZMEnow View Post
Beat me to it.
Old 06-28-2017, 07:35 PM   #10
Candr3535
Candr3535's Avatar
Drives: 2013 ZL1 Triple Black Vert M6 #5591
The S/c warranty is 120,000 miles and 10 years.
695 RWHP / 660 RWTQ @ 13.5 PSI
Dyna-Tech Headers Ceramic Coated w/Super Flo Cats, JRE Custom Rough Idle Racing Cam Package and 125 RWHP Pulley Kit w/ 28% pulley, Custom Tune by Ted, ID850 injectors, JMS Fuel Booster, NGK Plugs, MSD Plug Wires, Roto-Fab CAI, Roto-Fab Big Gulp, Elite Catch Can, Mild to Wild, 90mm VMaxx Ported Throttle Body, Skip Shift Elim., D3 Coolant Resevoir, Separated Clutch Resevoir, and Fuzzy Red Dice..
Candr3535 is offline   Reply With Quote
Old 06-29-2017, 01:41 AM   #11
STUNNAH
"BEASTM*DE"
STUNNAH's Avatar
Drives: 2013 ZL1 Black
Your dealer should have info on aftermarket warranty coverage...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S...
Dual 10" Kicker Comp S Subs 1200w...
STUNNAH is offline   Reply With Quote
