04-17-2018, 07:33 PM | #1 |
Drives: 2012 SS Join Date: Aug 2017
Bad tune?
I finally completed my cam swap and took the car for a drive. The engine light was on so I took it to get a scan. Below are the screen shots from the scanner.
I sent the PCM to TSP to install a tune based on the components I bought from them. Stage 1 Cam, D & D Delete, and headers with a cat delete. Overall the engine runs really bad... but you can tell from the codes. |
04-17-2018, 07:36 PM | #2 |
Started#gottalovethatblue
Have you tuned the car yet? If so, it appears as though something is off on the tune and/or something isn't hooked up correctly.
04-17-2018, 08:00 PM | #3 |
Boosted Moderator
I would send those screen shots to TSP and get on the phone with them ASAP.... If I were you....
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
04-17-2018, 08:06 PM | #4 |
I'm going to call TSP first thing in the morning.
04-17-2018, 10:12 PM | #5 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Nothing beats a proper dyno tune.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
04-18-2018, 02:11 PM | #6 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
I really envy TSP trying to figure out what sensor was disconnected or harness not fully plugged in or ground wire not connected etc over the phone.
04-18-2018, 02:56 PM | #7 |
@silversleeper, I was asking a question. Notice there was a ? mark.
If a missing ground is possible or something not fully plugged in, you could have simply suggested that. TSP suggested that a main plug to the PCM might not be fully seated so I'm going to try that when I get home. |
04-18-2018, 03:39 PM | #8 | |
Big Crow
Sorry I tried to help you for free and you can't see it from a different perspective. I'm not a certified mechanic and I didn't stay at a Holiday Inn Express so you probably shouldn't listen to me anyhow |
04-18-2018, 04:24 PM | #9 |
Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
Best ls motor tuner is Jeremy Formato in Lutz,Florida.
Phone # 813-476-7364 Tell him Ralph from PA sent you.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
04-18-2018, 05:52 PM | #10 |
I unplugged the PCM like TSP suggested and plugged it back in. The engine light is off now but it runs really, really bad. It stalls more times than not.
The only wire that I do NOT have plugged in is for the AFM system since I did a DOD delete. It feels like the car isn't running on all cylinders. I definitely have less power than before the cam and headers. I even tried OnStar to see what codes there are and they said there are no codes. I wonder if the AFM was not turned off when they applied the tune. |
04-18-2018, 06:07 PM | #11 |
Drives: 2013 ZL1 Triple Black Vert M6 #5591 Join Date: May 2013
Ding ding
695 RWHP / 660 RWTQ @ 13.5 PSI
Dyna-Tech Headers Ceramic Coated w/Super Flo Cats, JRE Custom Rough Idle Racing Cam Package and 125 RWHP Pulley Kit w/ 28% pulley, Custom Tune by Ted, ID850 injectors, JMS Fuel Booster, NGK Plugs, MSD Plug Wires, Roto-Fab CAI, Roto-Fab Big Gulp, Elite Catch Can, Mild to Wild, 90mm VMaxx Ported Throttle Body, Skip Shift Elim., D3 Coolant Resevoir, Separated Clutch Resevoir, and Fuzzy Red Dice.. |
04-18-2018, 06:33 PM | #12 |
I used an infrared thermometer and it looks like cylinders 5 & 6 are running 70-100 degrees cooler than the others.
04-18-2018, 07:52 PM | #13 |
Double check or reseat all of those coil wires, plug wires, injector wires, especially 5/6 like you said.
I would start one section at a time and reseat every damn cable or wire you see if you have to. It would be helpful if you could find out if 5/6 have spark.
04-20-2018, 06:23 PM | #14 |
After checking all the wires several times I figured I would try and get a scan even though the engine light wasn't on.
And this is what I got... "Lost Communication With Engine Control Module / Powertrain Control Module "A" CONFIRMED" |
