12-28-2018, 03:00 PM | #1 |
Drives: Gen V Viper GTS Join Date: Jan 2018
Power/Traction
The LT4 in our cars is a very good motor--lots of power and a fat power curve. My car is a 2018 A10 and I just love it (and I have had many performance cars in the past).
My only mods are RotoFab and Borla S Cat-Back and I will likely keep it that way. This forum is full of threads and posts of those modding with pulleys, tunes, new blowers, headers, etc. Warranty issues aside, how are the modders getting traction? In SoCal lately we have had cooler temps from high 40s to high 60sF and traction is an issue in the first few gears--largely stock! The setting of Sport + two pushes for Competitive Stabiliktrac or whatever is definitely a no go. Accordingly, what are those with 700rwhp and up doing for traction? Just curious. Thanks, and Happy Holidays! |
12-28-2018, 03:41 PM | #2 |
Thank you Al Oppenheiser!
Drives: Red Hot A10 ZL1 Convertible Join Date: Jun 2017
The OEM tires need heat to grip. Below 60F they will be slippery until they warm up.
12-28-2018, 04:39 PM | #3 |
Understood, but even after warming I can break traction in the first several gears using a heavy right foot.
03-13-2019, 02:33 PM | #4 |
Bump!
Seriously, are those with > 700 hp crank just using gas pedal management? My ZL1 will break traction at 70mph +, even on warm tires. If the LT5 ever makes it into our cars (future models), I hope there is a plan for traction! Last edited by Stealth7; 03-15-2019 at 01:50 PM. |
03-13-2019, 03:34 PM | #5 |
Drives: 18 ZL1 A10 & 18 2500HD Duramax Join Date: Oct 2012
I’m at 749rwhp SAE and I plan on using toyo r888rs 315’s for the street and a set of Mickey Thompson’s with 17 inch weld rims for dig races. It was 38 degrees one day and still on stock tires and it hooked from a 80 roll. When it just had an intake I had no traction issues at all... even on a cold day. You shouldn’t be losing traction at 100 mph plus with the mods you have.
Procharged 2018 ZL1 A10
2018 2500HD Duramax |
03-13-2019, 04:28 PM | #6 |
2012 RS 2ss
Drives: 2018 ZL1 2012 2SS WhippleCharged Join Date: Feb 2012
[QUOTE=Stealth7;10459834]Bum!
Seriously, are those with > 700 hp crank just using gas pedal management? My ZL1 will break traction at 100mph +, even on warm tires. QUOTE] Seems a bit optimistic , maybe you have a terrible alignment problem, grit on the roads or misreading the moves and noises the car makes at speed/Boost for slippage. Several have posted complaints about the cars factory alignment causing wandering at 100+ With air temps in the low 50's I used the PDR to do some 1/4 mile test, Stock Car, and only had wheel spin in 1 and 2 recorded best 11.6 at 122 .
2018 ZL1 A10 and 2012 2SS RS Whipple-Corsa-RotoFab-ZL1 Diff 3.73 Pfadt ZL Stage 3 Suspension+
03-13-2019, 07:18 PM | #7 |
No alignment issues, and I have had plenty of sportscars. This is just pure hits of power to the rear wheels. My car has 6,400 mi. on it so I still have tire left as well.
Throttle management is really the solution, but with increased power of 100-200rwhp, traction would be silly. It is not an accident that so many performance cars now come with AWD. |
03-13-2019, 08:34 PM | #8 | |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
The HP wars have outpaced tire technology advancements. AWD is the only way to keep up.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
03-14-2019, 08:53 AM | #9 |
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
Something doesn't sound right. I've always felt I have had more traction than I'd like to have when I'm trying to play. Even with full air in the rear tires, I can turn everything off, and floor it at a stop light, and it will just lightly spin as it accelerates hard. I have to hold the brakes to do any massive burnouts or cut the wheels pretty deep to make it start drifting. Now it does liven up with cooler temps, but still not what you'd expect with our power levels. Guess it's a good grippy setup and torque management that make it hook so well.
Life's Short, Live Fast! https://youtu.be/rTUv2p4T7OA 10.94 at 128 mph, 11.13 at 127mph 870 DA, https://youtu.be/e_X_LcpFp50 11.19 at 127mph 1100 DA, https://youtu.be/OXQiCQdQuH4 11.40 at 125mph 1800 DA
https://youtu.be/uWba1qs8M6Q 11.52 at 123mph 3500 DA TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
03-14-2019, 10:31 AM | #10 |
Drives: 2017 ZL1 Convertible A10 Join Date: Aug 2017
I'm with the OP, but with OEM setup I wa fine. I now have RotoFab + TonyMamo TB + 2.3" upper griptech pulley + Borla Catback and a retune. The power increase is crazy and my car is all over the place. I installed brand new Michelin PS4's and got a 4 wheel alignment... same! I can no longer accelerate from a dig without fishtailing all over the place, and even pulls from a roll has the car swerving in any mode other than track mode... its almost not even fun anymore
**note** I have a convertible and thus do not have the electronic LSD, not sure if that should be such a huge issue... I'm going back to the tuner
'17 White ZL1 A10 Convertible - TM ported TB - RotoFab CAI - 2.3" griptech upper pulley - Kooks 1 7/8" Headers with High Flow Cats - Borla S-type Catback - Audio Overhaul - NavTV M650-GM - 20" BlackDiForza- Michelin Pilot Sport4S - Tuned at BRC Raceworks (606rwhp/675trq)
'14 CTS-V Coupe - ZL1 lid - Ported TB - Ported Snout - AirRad CAI - 8.66" lower - 2.55" upper- Greenbelt - SW Headers - SW Catback - Varimax Intercooler Pump - Track Attack Intercooler-Tuned at BRC Raceworks (551rwhp/516trq) '17 Maserati Levante- STOCK |
03-14-2019, 10:33 AM | #11 | |
03-14-2019, 02:38 PM | #12 | |
Drives: ZL1/335i Join Date: Apr 2014
03-14-2019, 08:28 PM | #13 |
Drives: 2018 Camaro ZL1 Join Date: Feb 2018
I have a whipple installed and estimate I have maybe 700whp or more. Below 60*F my car will spin it's tires under 70mph pretty badly. Above 60 though, I think my traction is pretty decent with the stock tires. I have R888R's sitting at home but will install them when I get some more mods and traction REALLY becomes a problem.
03-15-2019, 03:53 PM | #14 | |
