11-17-2011, 11:01 PM | #1 |
The thin blue line
Drives: 2012, 2SS/RS,LS3,IOM/Beige Join Date: Aug 2011
LS3 surging
I've had my 2012 2SS/RS, LS3 for appx a week now and I just noticed the other morning that after I pulled out of my driveway that it was surging slightly while going slowly. The next day my wife told me that she noticed it as well. Is this normal with the LS3, because we didnt notice any surging with the L-99, A6 vert that we had? It has only done it on cold mornings. It has never done it when the vehicle is well warmed up after being driven a while of if the temps outside are much warmer.
11-17-2011, 11:04 PM | #2 |
Building the Beast
it happens with mine, nothing crazy. like you said, only when the engine is cold...i dont believe its anything to be worried about, just the LS3 chugging through its immense horsepower =)
11-17-2011, 11:08 PM | #3 | |
Aviation guru
Drives: 10 1SS, 09 Acadia, 90 K1500 Z-71 Join Date: Aug 2010
11-17-2011, 11:25 PM | #4 |
The thin blue line
No,..... it dont do it when the clutch is engaged, just when it cold and cruising at very slow speeds. Never later in the day when its warm outside or after the engine has warmed up. It didnt seem like such a big deal but I just wanted to see if I was alone with this issue or not.
11-18-2011, 12:02 AM | #5 |
Drives: 2011 Chevy Camaro 2SS Join Date: Oct 2011
Mine does the same thing in the morning as well
11-18-2011, 12:09 AM | #6 |
Official Lounge BAMF
a lot of car's do that..... most car's idle higher when cold.... its just trying to idle up, the bigger the engine, the more metal there is to have to heat up.
11-18-2011, 01:28 AM | #7 |
LS3 Black Widow
Drives: 2012 45th 2SS LS3 and 1968 Mustang Join Date: Nov 2011
Yeah I'm pretty sure it's just the fact that it doesn't like to idle low at slow speeds. I wouldn't be too concerned about it if I were you.
11-18-2011, 05:12 AM | #8 |
Hating prius's since 1997
Drives: 2010 Camaro 2SS/RS (JENNA) Join Date: Apr 2011
Let it warm up and get to operating temp. Mine does it unless I let it warm up.
PIPE
11-18-2011, 02:21 PM | #9 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
Same thing here. No big deal
11-18-2011, 02:24 PM | #10 |
Drives: 2014 Sonic, 2010 Camaro SS Join Date: Jan 2009
11-18-2011, 02:28 PM | #11 |
Drives: CGM 2SS/RS, 1987 & 2014 Silverado Join Date: Oct 2010
Fly by wire.
11-18-2011, 02:41 PM | #12 |
Zippy Lemon #109
Drives: 2010 SLP ZL575 #109 Join Date: Oct 2011
I wonder if this has anything to do with closed loop vs. open loop operation of the ECU?
Quoted from another site: "Open loop. This is when the engine runs with out useing its sensors, like the O2 sensor. It runs in open loop when cold at startup because some things dont work untill warm(O2 sensor!). When running in open loop. You engine runs inefficiently and has less power. Its also hard to pass emissions tests in open loop. basically, when running in open loop, you engine is running "dumb" its just running off of a pre-determined script not really useing any of the functions of the computer. Just like a carbureted engine. This is also your engines "limp mode". Closed loop is when the engine is warm and useing all its functions and sensors. Making it the efficient, powerful engine that it is." So perhaps the engine is in "dumb mode" when cold and thus the surging occurs as the load shifts (bucking)? I dunno...just thinking aloud.
2010 SLP ZL575 #109
11-18-2011, 03:35 PM | #13 |
Drives: 2020 Summit White LT1 M6 Join Date: Sep 2011
mine does this when its cold or after having just started before it warms up. nothing to worry about!
11-18-2011, 03:40 PM | #14 |
love. my. car.
mine does it when it's warm at around 8 mph with the clutch fully engaged.... mmm cam lope...
But seriously, it's normal. The car will do it when its warm as well when you find that "sweet spot" It's because the LS3 cam is more aggressive than the L99 cam
Similar Threads | ||||
Tucson Camaro's | FLYNNZL1 | USA - Southwest | 10387 | 10-21-2023 10:39 AM |
Introducing our hand ported, polished, and powdercoated LS3 throttle body! | ThePowderPro | V8 Bolt-Ons & Tunes | 111 | 03-11-2012 07:55 PM |
From L99 to Ls3 | LEADfoot927 | 5th Gen Camaro SS LS LT General Discussions | 30 | 06-07-2011 09:01 PM |
LS3 and L99? | black2black10 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 26 | 05-07-2010 12:58 AM |
Specs on L99 vs LS3 .... | Bowtie Junkman | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 3 | 04-28-2010 12:26 PM |
