#Camaro6
AWE Tuning
Old 09-10-2018, 05:14 PM   #1
Stealth7
Drives: Gen V Viper GTS
Battery Tender Pigtail Attachment Ideas
All:
My car is an '18 ZL1. Any slick ways to connect the quick-connect pigtail to the Battery so that the power cord can connect without having the trunk (location of battery) or hood (location of duplicate jumping terminals) open?
My body shop guy says that we really need to connect the tender to the battery since the hood terminals are too far away.
Thanks for your thoughts!
Stealth7 is offline   Reply With Quote
Old 09-10-2018, 06:13 PM   #2
Michael52
Michael52's Avatar
Drives: 2018 Black ZL1, 1977 Yellow 308GTB
Originally Posted by Stealth7 View Post
All:
I connect my battery tender to the connectors under the hood when I store my car over the winter and no issues, if that helps. My 911 allowed me to use the cigarette lighter for the battery tender. Have been doing this for years without actually connecting to the battery itself.
Michael52 is offline   Reply With Quote
Old 09-10-2018, 06:39 PM   #3
Stealth7
Thanks for the reply. Did you find an opening in the grill, etc. to feed the power cord in to connect to the pigtail, or do you need the hood cracked open or closed on the cord? Thanks!
Old 09-10-2018, 06:55 PM   #4
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Go to hobby shop and pick up set of quick connect battery charging terminals.. hide where you want.. velcro up under grill opening somewhere ?
ing for grip.
Are you in the NY/NJ/PA/CT region? Join us for autox fun at MetLife Stadium. HUGE lots, tons of runs.
http://www.motorsportsne.com/
Vtor_ZL1 is offline   Reply With Quote
Old 09-10-2018, 09:07 PM   #5
Michael52
Michael52's Avatar
I just let the hood rest on them while it's stored but Vtor_ZL1's idea makes sense too.
Old 09-11-2018, 06:39 AM   #6
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
I connect mine to the term block under the hood and last winter ran the cord out behind the front pass tire. This winter I plan to run the cord thru the hood latch opening and out the grille.
Old 09-11-2018, 04:01 PM   #7
itsadryheat79
itsadryheat79's Avatar
Drives: 2018 ZL1 1LE (2)79Z28 72RS 67SS 69Z
Send a message via Yahoo to itsadryheat79
In my 12 ZL1 I used the grommet that holds the battery vent tube as a pass thru. I just poked a hole in it adjusted the length to secure it and sealed it up. Then I could push it in or pull on it to retract it. When needed I pulled out the pigtail under the car.
The batterysaver charger I use has a fused pigtail with a cover to protect the exposed leads. https://www.batterysaver.com/store/p63/2087
Haven't looked in my 2018 yet but I'm betting there has to be a similar venting for the battery.
- Buttons and Skulls -
miss my annimated signature.
itsadryheat79 is offline   Reply With Quote
Old 09-11-2018, 06:34 PM   #8
RDBill
902HP 858TQ
RDBill's Avatar
Drives: 2018 ZL1 A10
I don't want to hijack his thread but I have a question.... I hooked up my battery tender to the terminal under the hood. The battery tender let's you know if it's charging the battery or if it's on storage mode. I hooked it up at night and the next morning it was still "charging". The battery tender was warm and I assumed I did something wrong because it should have been in storage mode. Maybe stealth7 is right and I need to hook it up directly to the battery? Maybe the small amps the tender provides isn't enough with the battery in the trunk?
RDBill is offline   Reply With Quote
Old 09-11-2018, 08:14 PM   #9
DangerZL1
Drives: 2023 Black ZL1 Auto
You’re probably right. The resistance in the wire between the trunk and the engine compartment is probably too high. I’d try moving it to the trunk and see if it works better.
DangerZL1 is offline   Reply With Quote
Old 09-11-2018, 08:21 PM   #10
Pollock
LT4 M6
Pollock's Avatar
Or your battery is just low. Battery tenders charge at a very slow rate.
I have been charging my cars from the hood location for a long time no issues. I put a towel over the fender where the cord lays and a 1x4 wrapped in a towel under the hood latch so the hood doesnt shut.
Pollock is offline   Reply With Quote
Old 09-12-2018, 04:12 PM   #11
RDBill
902HP 858TQ
RDBill's Avatar
Thank you guys!
Old 09-13-2018, 10:18 AM   #12
FLYNNZL1
Wicked ZL1
FLYNNZL1's Avatar
Drives: 2017 ZL1 A10 HBM
Send a message via ICQ to FLYNNZL1 Send a message via MSN to FLYNNZL1 Send a message via Yahoo to FLYNNZL1 Send a message via Skype™ to FLYNNZL1
I used the bolt on terminal connectors, the pigtail sticks out of the battery compartment insert in the side of the trunk. When I plug it in, I just rest the trunk lid down on it not fulling closing it with a microfiber between. This has worked great for 1+ years.
2017 Hyper Blue Metallic ZL1 A10/CF Hood Insert/PDR/NAV MODS: Rotofab CAI/V-MAX CNC Ported Throttle Body/Clear Bra/LED Reverse Light/Rock Guards/Lift Pads/Darkened Tail Lights/Ghost-Tinted LED Side Markers/Darkened 3rd Brake Light
FLYNNZL1 is offline   Reply With Quote
Old 09-13-2018, 01:05 PM   #13
Stealth7
I am going to try to attach the quick connect under the hood, secure the pigtail and thread the power cord through the grill when in use. Just need to find the locations!
