11-28-2018, 10:55 AM | #1 |
Drives: 2018 Camaro 2SS 1LE - Hyper Blue Join Date: Aug 2018
C7 Carbon Side Skirts
Hey guys. Anyone have experience with the C7 carbon side skirts on their 1LE? I was thinking about pulling the trigger here soon but was curious on their fit and finish for the cost
Anyone go with the Carbon fiber ones over the Satin black? Pics? Not sure what ones would looks best on the hyper blue https://www.c7carbon.com/2016up-cama...on-fiber-p-656 https://www.c7carbon.com/2016up-cama...9c7765273ca26e Thanks! |
11-28-2018, 12:30 PM | #2 |
Drives: E92 BMW M3 Join Date: Oct 2012
This thread should help, a few different options and opinions here:
https://www.camaro6.com/forums/showt...ight=C7+carbon
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned |
11-28-2018, 12:36 PM | #3 |
Drives: 2018 Audi TT RS Join Date: Jan 2014
I have them. I got them in “1LE Satin”. I can tell you that the fit of the side skirts are on point. However, their finish leaves a lot to be desired. It’s a very rough texture and doesn’t match our satin very well. A quick wrap would likely solve that issue, however.
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
11-28-2018, 12:40 PM | #4 | |
11-28-2018, 01:10 PM | #5 |
I don’t think that’s a bad idea at all, honestly.
2018 Audi TT ▊RS
11-28-2018, 04:50 PM | #6 |
what about cover with PPF? Wrap will get torn up like my hood
11-28-2018, 08:04 PM | #7 |
That was my thoughts also. Either get some already done in Satin Black and then get Xpel Stealth on them like I did my whole car. Or, get some in just primer, wrap it in Satin Black, then do Xpel Stealth. Both will cost similiar I assume. But if the one from C7 doesnt match or has a rough feel to it, then it sounds like I should get the non painted one.
However, the carbon fiber one does look glossy and smooth because that is essentially a wrap as well. So I could get that, then Xpel clear wrap it. |
11-28-2018, 08:15 PM | #8 |
Drives: 2018 red hot 1le Join Date: Apr 2015
Don’t do it they are terribly painted . Me and a friend ordered them and returned both sets and went with ACS. They are perfect match and paint is as close to stock pieces as you can get. Cost more but worth it.
11-28-2018, 08:22 PM | #9 |
Drives: 2018 Hyper Blue 1SS 1LE Join Date: Jul 2011
Love mine
Ryan B.
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic Car Build: http://www.camaro6.com/forums/showth...0#post10049680 |
11-28-2018, 10:38 PM | #10 |
11-28-2018, 11:14 PM | #11 |
Drives: 2SS 1LE Join Date: Oct 2011
I have them and the quality was great.
Everything happens for a reason, except when it doesn't, but even then, you can, in hindsight, fabricate a reason that satisfies your belief system.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
11-29-2018, 06:06 AM | #12 |
Drives: 18 1SS 1LE HyperBlue Join Date: Aug 2018
I have a pair - seem built well, but as stated above the "1LE Satin" finish leaves a little to be desired. My is a close match on color, but the "sheen" is off vs the mirrors, hood and splitter.
I wanted the rock protection so I am happy with the results Just don't be in too big of a hurry - I was given three weeks as a ETA when I was ordering, turned out to be six when it was all said and done
2018 1SS 1LE / HBM - ECS Novi 1500 S/C Tuned by Carl @ CJ Tunes
11-29-2018, 07:41 AM | #13 |
Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
Acs vs c7
Do the acs ones require holes to be drilled on the bottom and the lower angled section of the rocker panel like the c7 carbons or just the bottom? I'd prefer some where only the bottom part needs holes drilled.
11-29-2018, 08:37 AM | #14 |
Drives: 18 2SS 1LE Join Date: Jul 2018
You can attach them with just the bottom ones, but if you accidentally put your foot on the skirt when you get out, you're going to want the angled rivets installed.
