07-12-2012, 10:20 PM | #1 |
I like teeth.
Drives: #198 Join Date: Oct 2009
Cut low-intensity brake lights to make Afterburners stand out!
So apparently people have been doing this all the time, but I had no idea of this until just two months ago....
So here are my results! Before: Side by Side: Finished one side: Full Finished: Note that the top bright line on the brake lens is just the reflector on the lens. No way to take the picture without that lighting up. What do you guys think?
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517 "When you want to succeed as bad as you want to breathe, then you will be successful." |
07-12-2012, 10:33 PM | #2 |
Drives: 2010 Camaro LS V6 Join Date: Jul 2010
NICE. ill have to see this in person next week too
C-LO or Sonic
"Without Struggle there is no progress" I am your best nightmare! |
07-12-2012, 11:39 PM | #3 |
Drives: Fast, Faster, and O My God...! Join Date: Oct 2011
Looks real clean...I like it...congrat's on the mod sucess.
07-12-2012, 11:44 PM | #4 |
Drives: nothing Join Date: Nov 2010
I like how those look.
07-13-2012, 12:59 AM | #5 |
Drives: 1LT/M6 Join Date: May 2012
wait...what did u do? like did u change the lights out or something?
07-13-2012, 04:42 AM | #6 |
Drives: RED@2SS Join Date: Aug 2010
can u explane again what u did ?
07-13-2012, 05:10 AM | #7 |
knows 2 facts about ducks
You cut one of the outer prongs off of the light bulb takes 5 minutes. AAC includes instructions on how to do it with their afterburners.
07-13-2012, 06:28 AM | #8 |
HT5 COTW 9/3/2012
not really i got my afterburners and there was nothing about it in there, i learnt it from C5 guys.
07-13-2012, 08:14 AM | #9 | |
I like teeth.
1) first you take off the black plastic thing to get to the tail light bulb assembly. 3 push pins per side. 2) And then you twist the bulb out of the lens. Twist and then pull will allow it to come out. 3) Once you have the bulb assembly out of the lens, you grab the bottom of the bulb and pull it out. It is only held in by two metal clamp things, and it is very easy to just pull out. 4) Once you pull it out, look at the black plastic that is connected to the bulb. On the black plastic you will notice 4 metal wires. 5) Two of the wires are facing the outside, while two wires are facing the inside. With your finger pry up the two that are facing INSIDE and cut them. 6) Reinsert bulb to make sure that low intensity no longer lights up, but high intensity (pressing on the brake pedal) does! 7) Redo for three other bulbs and you're done! Took me about 25-30 minutes, and it was pretty easy Note: After cutting the two metal wires, don't push them back down against the plastic. I did that and that allowed for contact, which then allowed for the low intensity to light up. Just let them stick up and you should be fine
07-13-2012, 08:15 AM | #10 |
I like teeth.
yeah I've had them for a year and a half and just learned about them!!
07-13-2012, 08:18 AM | #11 |
By chance can you get us a picture of what exactly it is that you do or cut?
07-13-2012, 08:22 AM | #12 | |
I like teeth.
It is literally 2 gray metal wires per bulb
07-13-2012, 08:34 AM | #13 |
So correct me if im wrong but doing this, the tailights will not light at all until you hit the brake, correct? Even if the park lights are on?
07-13-2012, 08:36 AM | #14 |
I like teeth.
Yes exactly. The purpose of this mod is to make the afterburners INTO the parking lights like the concept car
Thread Tools | |
